Iridium - Motorola 9500 sources
Submitted: Friday, Jun 15, 2007 at 08:42
matesinko
Dear Collegues, can anyone recommend a site / company from where it is possible to buy a Motorola 9500 for Iridium? Thank you for the kind help, MD"tD* SinkD4 - Budapest
Reply By: Member - TasGareth (TAS) - Friday, Jun 15, 2007 at 08:50
Have a look at this sight
asta.net .au/p22/Product-Detail-motorola-9505a
It has info you require I hope.
I am also looking at a sat phone so would be interested ih your oppinion
246988
Follow Up By: Member - TasGareth (TAS) - Friday, Jun 15, 2007 at 08:52
Oh dear that takes you to the American string Association
www.asta.net .au
lets see if that works
507811
Follow Up By: Member - TasGareth (TAS) - Friday, Jun 15, 2007 at 08:54
forget the hyper link it is going to the wrong place but
www.asta.net.au
iswhere to have a look
507812
Follow Up By: Willem - Friday, Jun 15, 2007 at 08:58
I have a Motorola 9500. Bought it 4 years ago off an EO Member.
I am with Telstra /Iridium and have never had an issue with satellite access, or the phone. Sometimes there is a bit of an echo when talking but that must have to do with atmospherics or alike. Have used the phone all over Australia and in Africa too.
507813
Follow Up By: Member - TasGareth (TAS) - Friday, Jun 15, 2007 at 09:31
Willem
Can you use the SIM card from your GSM phone with Global roaming or is it a seperate system ?
507819
Follow Up By: Willem - Friday, Jun 15, 2007 at 11:10
TasG
Used to but not any more as the system has changed. I believe you may have to upgrade to a newer phone to operate on the 3G network. Might have to check out Telstra site.
The Sim card capability isn't really much help as you are charged Global Roaming rates and that could end up being just as expensive as using the Satphone. I limit my call to 4 mins max...about $10. Its amazing how much you can say in 4 mins...lol
507834
Follow Up By: Member - TasGareth (TAS) - Friday, Jun 15, 2007 at 11:55
Thanks Willem
I am looking at buying a sat phone but find it hard to decide which way to go, but the Iridium 9505 is shaping up as the one. Also the lower price range.
What I was told was that if you get global roaming on your GSM phone, then you can insert the SIM card in your Sat phone and pay Sat rates but it saves you having to get another account and number, because it is all billed to the original Mobile number.
Maybe I habve got it wrong LOL would be just like me.
507852
Follow Up By: Member - Mike DID - Friday, Jun 15, 2007 at 14:29
If you have a Telstra GSM Simcard with Global Roaming, it will be recognised in a Motorola 9500 or 9505.
You will be charged about $3 a minute for outgoing and for incoming calls. Expensive, but you don't have to pay any monthly fees this way.
People just dial or SMS your normal Mobile number, but warn them there will be long delay and silent periods before the call connects. You don't pay for incoming SMS calls.
507876
Reply By: traveller2 - Friday, Jun 15, 2007 at 11:57
I've found my 9500 the same as Willem, bought it from another 4 wheeler who had no further use. The only down side I've found is that it can't send SMS but can receive them ok.
My conclusions on using the Telstra GSM SIM followed Willem's thinking too, calls are twice the cost and it ends up costing the same overall.
247028
Follow Up By: Willem - Friday, Jun 15, 2007 at 14:37
One thing good about Telstra Iridium Motorola 9500 and 9505 is that you can have 101 message bank on it. I haven't checked the cost for message retrieval but it is handy to be able to check every few days when out in
the desert to see if you are needed somewhere else...lol
507878
