3 way fridges
Submitted: Saturday, Jun 16, 2007 at 10:29
Grinch
I own a caravan with a 3 three way fridge. Is anyone able to enlighten me why these fridges are inneficient on 12 volt. I would have thought that having three sources of power they would all work at the same efficiency. It appears that gas is best, 240 volt second and 12 volt last.
I appreciate any information possible as we are currently looking at replacing the 90 litre fridge with a 175 litre fridge. I was considering a 12 volt job but I would have to spend more money on solar and multiple batteries to allow us to be away from power for a week or more.
thanks
Anthony
Reply By: Mike Harding - Saturday, Jun 16, 2007 at 10:43
3 way fridges require a heat source as their prime energy. On gas this is a flame and on 12V and 240V it is a resistive heating element. In all three cases the amount of energy required to keep the fridge cold is the same, about 80W for my 3 way. The gas flame can easily produce this much and at 240V only about 0.3 amps is required however on 12V 7A or 8A is necessary and once we start to pull those level of current it is hard not to create a voltage drop across connectors, wires, fuses etc and with only 12V to start with a drop of 1V2 means we have lost 10% of our power whereas on 240V a 1V2 drop equates to a loss of only 0.5% of power.
In short; at 12V ensure you use high quality connectors capable of carrying at least twice the fridge requirement, as thick a wire as sensibly feasible and keep wiring runs as short as possible.
Mike Harding
247203
Follow Up By: Rocky_QLD - Monday, Jun 18, 2007 at 07:38
Well said Mike
508420
Reply By: Member - Barry M (NSW) - Saturday, Jun 16, 2007 at 14:24
I agree entirely with Mike. 3 Ways are often denigrated on this site when the real issue is often inadequate wiring & connectors combined with long wire runs. .
While not supplying everyones needs, the 3 way sure does away with the need for
carrying a portable power station when running on gas....oldbaz.
247225
Follow Up By: kev.h - Saturday, Jun 16, 2007 at 17:56
And they are quite nothing like a compressor cutting in to spoil your sleep
Kev
508111
Reply By: Mick - Saturday, Jun 16, 2007 at 20:51
I have an old Finch which works very
well in the back of the Prado. The wiring to the socket is obviously "up to it" and the lead on the fridge is short. Previous owner had a long extension to run from cig lighter to boot and always complained that it didn't work properly on 12v. Set them up properly and they are fine!!
247301
Follow Up By: ozwasp - Monday, Jun 18, 2007 at 00:35
Hi Mick,
I'm pretty sure the Finches run a bit less power than the other chescolds.
They run 7.5 amps instead of 10 so there's alot less strain on the cig lighter.
I don't think the finches will cope in the hot weather as
well though, as they're not designed to freeze.... Better than nothing though!!
Cheers, Will.
508405
Follow Up By: Mick - Wednesday, Jun 20, 2007 at 10:03
Will, the fridge is not plugged into a cigarette lighter socket. It's a power outlet that is placed in the rear compartment for accessories and it is obviously heavier duty than a lighter socket. It's a matter of having equipment that's up to the job. A friend has the same fridge in a patrol and it works, but is only in the "better than nothing" category.
Cheers, Mick
508872
