Air Compressor
Submitted: Saturday, Jun 16, 2007 at 16:34
ThreadID: 46735 Views:2531 Replies:2 FollowUps:4
Just interested if anyone has had any experience with the Mega Grunt 4x4 Double Piston 200PSI Compressor
Ian
Reply By: Derek from Affordable Batteries & Radiators - Saturday, Jun 16, 2007 at 19:11
Hi Ian
I can only find this one, have you got a web link ?
Derek.
AnswerID: 247280
Follow Up By: Derek from Affordable Batteries & Radiators - Saturday, Jun 16, 2007 at 19:17
Hi Ian
Found it. It looks quite good but I don't have any feedback on them.
Double Portable & compact air compressor kit complete with hose, pressure guage and attachments. Suitable for filling 4WD tyres, air boats, inflatable toys etc. Inflates a standard 4x4 tyre from 15 to 32PSI in less than 1 minute!
Specifications
Maximum Air Flow 85 Litres/min
Maximum Voltage 13.8Volts
Working Pressure 150PSI
Maximum Pressure 200PSI
Duty Cycle 40mins @ 40PSI
Weight 5.5Kgs
Supplied with Protective bag and all hose fittings
FollowupID: 508127
Follow Up By: Member - Ian F (WA) - Saturday, Jun 16, 2007 at 21:39
Hi Derek,
A WA Perth site has these for $179.00 inc. GST
Ian
FollowupID: 508157
Follow Up By: Member - Ian H (NSW) - Saturday, Jun 16, 2007 at 21:55
I have one of the single piston types and it works well especially after I replaced the cable with a big thick mother. 6mm I think.
FollowupID: 508160
Follow Up By: Derek from Affordable Batteries & Radiators - Saturday, Jun 16, 2007 at 22:32
Hi Ian
Yes it must be the same link.
Derek's link to WA supplier
FollowupID: 508176
Reply By: Rainman WA - Saturday, Jun 16, 2007 at 22:34
I bought a Grunter compressor from Marlowes a few years ago for around $70, when it died I bought a twin head compressor that was rated to produce 150 litres per minute and cost $245.
It was quick but that was about it. It sometimes wouldnt start, and when it did it "reved" up and down and the power cable got real hot to touch and the on/off switch kept dislodging itself. The last time I used it the fuse in the cable melted and I had to drive about 20kms into Lancelin to pump up my tyres.
After that I decided no more cheap compressors and went out and bought a Bluetongue. Its not as fast but it will be around for a long time I reckon.
AnswerID: 247322
