AnswerID: 18919 Submitted: Thursday, May 01, 2003 at 19:25
Chris
replied:
wim
I fitted a replacement 130 l tank from 4wdsystems about 3 mnths ago. Here are my experiences
*2001 TD Jack
*fitting was easy, but it is a 2man job
*allow 1/2 day
*simply disconnect hoses & filler from old tank, fix to new
*tank should NOT rattle loose if fixed correctly (use locktite)
*have done bad corrugated roads since - no problem
*departure angle affected, but not much if you have a towbar which already affected departure angle
*notwithstanding above, the Jack's departure angle is pretty good to start with, you would be hung up on your transfer case not departure angle
*IMPORTANT clean tank beforehand to get rid of metal chavings. Drain after 1 tank of use, and replace fuel filter.
*about $650 to $700 from memory
* an aux tank is much more expensive (+$1200) but does bring the weight forward
Hope this helps
Chris
Reply 5 of 7
FollowupID: 12196 Submitted:
Wednesday, May 07, 2003 at 20:31
Chris posted:
Savvas
Sorry for the late reply, I was away for a while.
The tank has a magnet in the drain tank. I simply filled with a few litres of diesel, taped the openings, and rolled the tank around on the lawn. There were a lot of metal shavings collected on the magnet. That was why I again drained the tank after some use, again finding more metal shavings. Replaced my fuel filter after the first tank also.
Note also that they advertise the tank as 130 l, but I could fill only 128 l after draining. Of this I reckon 3 or 4 litres are unusable due to pickup, leaving 124 - 125 usable litres.
Some other tanks (OL) advertise 135 litre tanks.
Chris
FollowUp 3 of 3
