Pajero rim offsets
Submitted: Tuesday, Jun 19, 2007 at 11:17
ThreadID: 46849 Views:3129 Replies:4 FollowUps:2
Howdy Crew, wonder if anyone can help me with my question,, what 6stud rims have the same offset as my 84 pajero, or what other wheels can i safely put on there without scrubbing the tyres or the body, i wanna stick to 15inch rims since the tyres seem to be cheaper & the choice is quite good. i dont have any body or suspension lift currently, but may do later. Cheers & happy trails to you all.
Reply By: Trevor W(Brisbane) - Tuesday, Jun 19, 2007 at 11:21
I have a set of 4 from a 96 model with tyres in my shed in Brisbane
can sell them if you want to get them
AnswerID: 247857
Reply By: Stu050 - Tuesday, Jun 19, 2007 at 13:21
G'day,
The Nissan Navara offset is the one that you want.
It will fit a 31x10.5 inside the guard on a NJ '94 no problems.
AnswerID: 247872
Reply By: Member - Oldplodder (QLD) - Tuesday, Jun 19, 2007 at 15:54
GQ Patrol RV (94 to 97?) is also the same.
Also have some Navara rims which are the same.
They are 16x6 RV rims on my 96 NJ GLX (no fancy plastic bits on the outside) now.
Within 1 or 2 mm of stock.
All are 12mm studs and the right PCD.
Used to have a 85 NB and they look the same offset.
I was running 7x15 on it with 31x10.5x15 without any clearance problems.
The 7" rims usually have most of the 1" extra on the outside over a 6" rim, so the tyres are almost flush with the body.
You will need to check the centre hole is the right diameter too.
Some are 100mm dia and some 110mm dia.
Double check your current pajero rims.
AnswerID: 247893
Reply By: Member-Granpa Joe - Tuesday, Jun 19, 2007 at 20:49
ROH wheels make wheels for your 4b, They are cheap and well priced at $50 to $60 each. At least you know they aren't buckled.
www.roh.com.au/asp/product_catalogue.asp
They aren't shown as being available in the fitment guide, although I purchased a set of five in the triton/pajero offset some time ago.
Hope this helps.
AnswerID: 247952
Follow Up By: Member-Granpa Joe - Tuesday, Jun 19, 2007 at 20:50
Oops, wrong link........ Look in the steel wheels section.
FollowupID: 508778
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Jun 20, 2007 at 08:42
Good point Granpa,
The nissan rims I am finding these days that fit are 10 years old. Getting a bit knocked around.
FollowupID: 508864
