Quest vs ?
Submitted: Wednesday, Jun 20, 2007 at 16:39
ThreadID: 46888 Views:2786 Replies:12 FollowUps:7
After reading all the posted threads and now leaning towards a Garmin instead of a Magellan, can anyone tell me if buying a Quest and spending around 850 dollars is worth it. No arguements please, just plain simple facts.Will Quest do the job when I go out into the scrub.
fujimiester
Reply By: bauer - Wednesday, Jun 20, 2007 at 17:03
just bought quest last friday $745 so far so good but can't get the road maps into oziexploer so got natmap raster 2005 as well although mapsource is a lot easier to use (training the wife to use it)
AnswerID: 248092
Follow Up By: mattie - Wednesday, Jun 20, 2007 at 18:16
Hi Bauer
where did u purchase the Quest from? I have been watching the gps posts as i am tossing up which way to go as well, the 276c has a bigger screen and does the same things as the Quest but is a lot dearer and not sure if the larger unit is worth it? It is probably a lot easier read if driving by your self.
Is the mapping u buy from Garmin worth the $(for the off road tracks particularly) or do u just down load from web sites for free as it seems every one else does; are these not as accurate as the Garmin maps?.
Mattie
FollowupID: 508935
Follow Up By: bauer - Wednesday, Jun 20, 2007 at 19:33
contact communications in gawler sa they have store on ebay under the name
UHF_GPS_Gadgets_plus_more sent them email then went to gawler and bought one plus uhf set . (quest $729)
FollowupID: 508950
Follow Up By: mattie - Wednesday, Jun 20, 2007 at 20:43
Thank u for that i now live in QLD but i will still give them a try.
Mattie
FollowupID: 508971
Reply By: Skippy In The GU - Wednesday, Jun 20, 2007 at 17:14
At $750 it's even better, yes it is a good product, it also comes with the Mapsource City Navigator V7 for general city and country maps
If you want better outback / remote topo maps you can download for free and install Shonkymaps.
AnswerID: 248093
Reply By: Member - John D (VIC) - Wednesday, Jun 20, 2007 at 17:21
Hi Fuji
I bought a Quest for my upcoming trip to the Kimberleys starting in July, using the MapSource software that is supplied, I created all the routes & waypoints that I needed for the trip on the pc and downloaded them to the Quest. I even did a small route from home to work (45 klms) just to see how good it was, the voice directions & the plug-in speaker worked perfect.
To find out how accurate the Quest was I decided to find a Geocache which was hidden close to home, when the Quest indicated that I was at the coordinates given for the geocache, I found I was only about four feet away, I reckon that is fairly accurate.
I bought mine online through Johnny Applseed and paid for express delivery and it arrived the next day.
I couldn't be happier with the Quest.
Regards,
AnswerID: 248095
Follow Up By: Member - Doug T (W.A) - Wednesday, Jun 20, 2007 at 23:18
Good to see another happy Garmin user, now you can see why I like them and recomend them , My first was a GPS 12, then GPSII, MAP 176c,those 3 long sold and now I have a Quest and a Nuvi 660.
Doug
FollowupID: 509006
Follow Up By: Member - andrew B (Kununurra) - Thursday, Jun 21, 2007 at 09:45
Gday John & Doug
I am in the same boat and will always recommend Garmin. I've had my GPS 76 for a long time now (bought it before the 76 map came out - would prefer one with maps and memory)
I have finally got around to getting adapter plugs etc to use it with the laptop, and it has definetley worthwhile. I've got file conversion software now so I can make tracks on Google earth, convert them to most common files, then use them either on Mapsource (with shonkymaps) on the laptop or put them strait onto the GPS for use without maps. I have also come across some software for using google earth as the mooving map, but haven't worked out how to use it yet. Very handy!
Cheers Andrew
FollowupID: 509048
Reply By: ZukscooterX90 (Qld) - Wednesday, Jun 20, 2007 at 18:49
Imho yes. I have one & even though i have not fully tested it out in the outback & what have you,i am happy with my purchase.
Cheers Bob.
AnswerID: 248124
Reply By: Robin Miller - Wednesday, Jun 20, 2007 at 19:52
A Quest isn't one I would consider for out in the bush as its more Orientated to use of pre-loaded maps.
276c and 60c series garmins are more along the line I choose , because basically while many main routes are included in mapping there are lots of errors and out of place tracks such that in bush situations I find internal mapping relatively useless.
Main thing I do for this type of use is load in tracks I have previously recorded or from say this website, and essentially use these as a guide.
The 2 units I mentioned allow about 15 such tracks to be easily pre-loaded, in high definition, and followed without confusion of other data.
Situation is quite different for fixed roads and here the now common Navigators are useful - there is a case for both types of function.
Robin Miller
AnswerID: 248140
Reply By: Member - Doug T (W.A) - Wednesday, Jun 20, 2007 at 23:09
fujimiester
Absolutly no problems, will guide you from Perth to the tip of Cape York ,or to a street in Birdsville, will record 4100klm of the journey, and you can make your own routes, and you will get a CD of the Mapping Software to use on you PC and Laptop if you have one, you could also add T4A into it also,
www.ja-gps.com.au/garmin_quest_1.html
AnswerID: 248175
Reply By: Member - Navigator 1 - Thursday, Jun 21, 2007 at 01:09
Garmin 276C is the way to go. Screen clarity is excellent.
The outback calls
AnswerID: 248187
Reply By: fujimiester - Thursday, Jun 21, 2007 at 07:54
thanx everyone. Is the 276c portable???
AnswerID: 248200
Follow Up By: Skippy In The GU - Thursday, Jun 21, 2007 at 08:57
Yes it has it's own battery but a bit big to carry through the scrub for bush walking, if thats what you want to know
FollowupID: 509036
Reply By: Big Mike - Thursday, Jun 21, 2007 at 09:26
Have had my quest now for nearly 2 years and it is fantastic. Voice guidance is great for around the city and towns and tracks are easily downloaded using ozi. I reckon its one of the best things I have ever bought. Got mine from Johnny appleseed in Brisbane, they also run courses to get the most out it, (no connection to them, just a happy customer). If I had to find a negative, it would only be screen size, but you can't have everything. Handy to stick in your pocket when bushwalking.
AnswerID: 248214
Reply By: fujimiester - Thursday, Jun 21, 2007 at 18:47
Seeing that I am mentally challenged in GPS, I will have to drive to St Kilda Rd and pop into Johnny Appleseed. Why can't they just load a desert tracks map or similar onto the damn unit and make life so much simpler. I don't have the patience to be buying and loading maps onto a laptop (if the missus lets me use hers) and then downloading onto the unit. Thank you for taking the time out to reply. Wave when you see me pointing the laser at you to clock your speed.
fm
AnswerID: 248320
Reply By: Mr Z - Monday, Jun 25, 2007 at 09:42
I'm looking at the nuvi 660, how does this compare to the quest doug?
thanks
AnswerID: 248887
Reply By: Member - Doug T (W.A) - Friday, Jul 13, 2007 at 18:32
fujimiester
I just done a demo page for the Quest, copy and paste this URL into the address bar.
www.doug-and-dusty.id.au/display1.htm
Doug
AnswerID: 252255
Follow Up By: Gone Bush (WA) - Friday, Jul 13, 2007 at 18:49
Doug that Quest page of yours is outstanding. As you know I have the 660. It does everything I need at the moment and my head hurts just contemplating learning how to use another device.
So much technology, so little time.
FollowupID: 513333
