Yep. ANOTHER Fridge Question
Submitted: Wednesday, Jun 20, 2007 at 20:10
ThreadID: 46898 Views:2349 Replies:5 FollowUps:4
G'day all, i've got a Waeco 50L fridge with digital display & was wondering what temperature should i put it on to freeze meat (steak, chops, etc)?
Thanks in advance.
Cheers, Brad
Reply By: Member - Michael R (NSW) - Wednesday, Jun 20, 2007 at 20:39
Hi Brad,
I run mine on 3 lights, which gives an internal temperature of around -1.7 degrees. Food and drinks are not frozen at this point (but very cold). Anything above 5 lights will start to freeze with no problems. Part of it will be trial and error, but if the meat is frozen at home, then 5-6 will keep it there.
Michael
AnswerID: 248151
Follow Up By: Member - Michael R (NSW) - Wednesday, Jun 20, 2007 at 21:09
Ooops - forgot to mention mine is not the digital display, but the older version.
FollowupID: 508976
Follow Up By: Slapnut - Friday, Jun 22, 2007 at 21:16
Only fresh water will begin to freeze at 0 Deg. Anything with sugar in it (beer/softdrink) will require -5 deg or more to freeze.
Trial and error is the way to go, as i have learnt, while the wife sits back us guys will tinker with stuff like the fridge and batteries etc.
FollowupID: 509426
Reply By: Member - Phil G (SA) - Wednesday, Jun 20, 2007 at 21:17
Brad,
Can't answer the Waeco bit, but can I suggest you go to Jaycar and buy one of their $19.95 indoor/outdoor digital temp things. Put the outdor probe inside the bottom of the fridge and cabletie the gauge to the outside. they run on a single AA battery which lasts a couple of years. That way you know whats going on.
phil
AnswerID: 248157
Follow Up By: simple - Wednesday, Jun 20, 2007 at 23:27
i was trying to work out what a "cabletie" {cab-lettie} was......had to read it again
FollowupID: 509008
Reply By: Brew34.5(SA) - Wednesday, Jun 20, 2007 at 21:19
To freeze meat you should be looking at at least -10 deg.
AnswerID: 248159
Reply By: Member - Jiarna (NT) - Wednesday, Jun 20, 2007 at 21:25
The colder the better. The deep freeze at home sits at about -18, while the freezer compartment above the fridge sits at around -6.
Keep in mind that if you vacuum pack the meat (cryovac) or get the butcher to do it, you won't need to freeze it at all. Saves a lot of wear and tear on the fridge.
AnswerID: 248161
Reply By: GeorgieGirl - Thursday, Jun 21, 2007 at 09:53
Hi Brad
We purchased a Waeco CF-80 a few months and then had problems with the kitchen fridge. So I turned the Waeco on. I wasn't sure of the correct temperatures so I rang Waeco and they informed be the fridge had to be set at 0 or -1 degrees and the freezer I can't quite remember of the top of my head but about -12 degrees.
Just ring the number on the back of the brochures.They were very helpful.
Hope this helps.
GeorgieGirl
AnswerID: 248219
Follow Up By: SARocks - Thursday, Jun 21, 2007 at 14:13
fridge should be kept 2C to 4C and frozen -18C
FollowupID: 509075
