To all Prado Guru's
Submitted: Wednesday, Jun 20, 2007 at 23:05
Ford Rodeo
Just wanted to know if anyone has info on weak rear (or front) diffs in Prado's (2003 T/D manual) And if there is a problem, how it may be rectified? A mate of
mine is travelling with me (in his Prado, towing camper-trailer) to the Cape and surrounds and has heard some nasty stories re diff breaks etc.... Any info appreciated.
Thanks Phill
Reply By: Skippy In The GU - Thursday, Jun 21, 2007 at 00:03
Don't ever do a reverse snatch recovery with them.
248182
Follow Up By: PeteS - Thursday, Jun 21, 2007 at 07:19
Hi Skippy
Wondering if you know of any situations where this hass occured with diff damage.
Would be interested on the in and outs of it if you do.
PeteS
509022
Follow Up By: Skippy In The GU - Thursday, Jun 21, 2007 at 08:52
There is a guy in our club that has blown 2 diffs in the high country and once at
beachport on Australia day 2006,
I know once in the hi country it broke as the wheel came down and he still had the front lockers on, not sure the second time and in
Beachport he did a reverse snatch recovery. A million of 4wd'ers would have seen it on the back on the tilt tray coming back to
Adelaide. I'm not putting Prados down I love them, I'll try and get the photos on all 3 breakdowns and send them to you if you what, I won't put them on here. He did have ARB diff locks in the front and rear. The gear are cut differently in the prados and it is a weak point. He also did damage to the transfer case at the same time I believe. This guy took the Prado
places others wouldn't go.
There are people that might have had them for 10 years and have never had problems but they might not take them off road either, truelly off road.
As I said before I do love them and I might buy one when I retire.
509034
Follow Up By: PeteS - Thursday, Jun 21, 2007 at 09:23
Hi Skippy
Would really appreciate the info & pics. More interested for my own sake and general knowledge of limits etc.
Some of the guys on "pradopoint.com" have had rear diff problems and some have/are putting diff lockers on which they hope will rectify the problem.
Are you are a ExplorOz member? If so could you send me a message re the pics.
If not I will give you my email address.
PeteS
509043
Follow Up By: Scoey (QLD) - Thursday, Jun 21, 2007 at 15:05
I thought that the practice of reverse snatching should be avoided in any vehicle? I know it's sometimes unavoidable but still that's what I've been taught!
Scoey!
509083
Follow Up By: DaveNQ1 - Thursday, Jun 21, 2007 at 21:22
Scoey,
Thats exactly right. A reverse snatch should ideally not be done in any vehicle. The crownwheel to pinion gear mesh is not designed to be under full load in reverse. Even tractors are the same. A lot of people are not aware of this and therefore have dramas.
Dave.
509192
Reply By: Member - John (Vic) - Thursday, Jun 21, 2007 at 00:09
Never heard of Playdoes having an issue?
Only 100's and Hilux's, but then again anything is possible
248183
Follow Up By: Member - Davoe (Nullagine) - Friday, Jun 22, 2007 at 13:57
Is not widely known but without being a huge issue it seems there rear diffs are a bit weak. My Sisterand BIL blew theres when it wasnt that old (maybe a year) Was fixed under warranty
509358
Reply By: Member - Shane D (QLD) - Thursday, Jun 21, 2007 at 08:16
wanna hear a horror story?
I was at
Birdsville in early may when I heard that Theo recovered a Prado that had blown a rear diff.
He was towing an off road camper and was 200 ks in to the simmo,we reckon that recovery would of cost $4-5000 because the camper had to be towed out seperatly making the bill double.
prado's have semi floating axles,so you cant pull the inner axles out and drive on front diff
248204
Reply By: Mick - Thursday, Jun 21, 2007 at 08:32
Had Prados(3) for 10 years. Lots of mates with them too. None have had any diff issues. Only my personal experience of course. Suggest you sniff around workshops for a loose lipped mechanic if you want to find more. Don't pay too much attention to responses on here as the Patrol drivers (those who can't afford Toyotas will invent stories to justify their choice of vehicle lol)
248205
Reply By: Glenn_co - Thursday, Jun 21, 2007 at 08:43
We have had at lest 6 rear diffs go in our club. Teeth broken off cown and pinion. I have personally seen 2 go.
Glenn
248209
Follow Up By: Skippy In The GU - Thursday, Jun 21, 2007 at 08:54
Thank you Glenn. :-). don't tell them you drive a Patrol or they won't believe you either. :-)
509035
Follow Up By: AndrewX - Thursday, Jun 21, 2007 at 09:57
That's amazing Glenn .... 6 in one club .... is it related to the type of driving your club does perhaps - after all anything can be broken if it's abused enough. There have been no failures in my club but we aren't "hard core" drivers if you know what I mean. We've had outback trips including the Simpson and many high country trips so we're not just shopping trolleys. I'd be most interested if you would describe the situations in which the diffs failed so that I and others can perhaps avoid such a failure in future. Thanks Glenn
509051
Follow Up By: Member - John (Vic) - Thursday, Jun 21, 2007 at 11:48
I'm with you Andrew, I'm in a Toyota Club here in Melb which has literally dozens of Playdoes and have heard or seen nothing with Playdoe diffs,
suspension on the Grande, yep! diffs on 100 series and 78 / 79 series, yep! but no Playdoe diffs.
509060
Follow Up By: Paps - Thursday, Jun 21, 2007 at 20:35
That's timely information. I'm in the process of deciding between a GU or 79 tray. I didn't realise to 79 series Toyotas had weak diffs. Cheers, Paps
509179
Follow Up By: Member - John (Vic) - Thursday, Jun 21, 2007 at 21:29
I should have said front diff's Paps, do an archive search for details.
509193
Follow Up By: Glenn_co - Friday, Jun 22, 2007 at 08:26
Two rear 120 series diffs at Rover
park
One rear 120 series diff at Crystalvale 4WD
park
One front 90 series diff at
The Springs 4WD
park
One front 90 series diff at Imbil
state forest
One rear 120 series diff at Clubs drivers training
A club member complied a list of Pajero and Pardo (mostly Pardo's) so he could send it to Toyota to prove that they do have a problem with was in response to him speaking to Toyota about the high number of diff breakages and of course Toyota denying any problem with their diffs.
I will see if I can get a copy of the list.
Glenn
509294
Follow Up By: Member - Davoe (Nullagine) - Sunday, Jun 24, 2007 at 19:43
were there any TD failures?I wonder how much has to do with the 190kw in the 4.ol 120 series
509699
Reply By: Shayne - Thursday, Jun 21, 2007 at 08:56
I have had front diff fail in IFS Turbo diesel Toyota landcruiser
took 5 teeth from crown wheel.
When rang a diff repair people in our area was told that Pardo 120 & late model Hilux also have same type of problem.
I have yet to fix it as Toyota are not going to pay.
248212
Reply By: Member - Phil G (SA) - Thursday, Jun 21, 2007 at 10:09
90series tended to break mostly front diffs, and occasionally rear.
Then they upgraded the front diffs with the 120series, and bolted more horses under the bonnet, so the 120series breaks the rear diffs.
Treat them
well, and its unlikely you'll have a problem.
248222
Reply By: traveller2 - Thursday, Jun 21, 2007 at 10:43
I'd reckon that part of the problem is that when touring they are overloaded (like most late model 4wd wagons) by lots of people and when in heavy going something has to give.
I've only seen one go personally but have heard of a few others going.
Rear diff, heavily laden, very steep climb in the
Vic high country, he would probably have been ok if he hadn't stopped to take a piccy.
248228
Reply By: lc_120man - Thursday, Jun 21, 2007 at 10:52
It could happen if you don't have light rear foot..
I.e while one front wheel in the air and spinning and there are still power applied
to the
wheels. Once the tyre has landed there is shock transmitted to the diff and
it can brake the teeth of the crown wheel... A lot of landcruisers brake front diffs going to Cape....
So it basically comes down to how good the Prado setup is... I.e. if it got 2" Lift and
good MT type tyres the chances of breaking diff is much less. If it gets bogged
in the cape with CT better give it a snatch to be on the safe side (specially when getting out of the river bank)...
My Prado has been in a lot of
places where not many 4wds go and almost 3 years later still no problems...
248229
Follow Up By: Ford Rodeo - Thursday, Jun 21, 2007 at 12:13
LC,Thanks for your input. A few Q's, have you got lockers? Have you heard that they might help diffs?(air or auto lockers) What does "light rear foot" mean?
Thanks Phill
509062
Follow Up By: lc_120man - Thursday, Jun 21, 2007 at 12:46
Phil,
I got lockers which were fitted only a couple of weeks ago..
Oops.... I meant light right foot. LOL.
509064
Follow Up By: Member - 120scruiser (NSW) - Thursday, Jun 21, 2007 at 21:13
Mine 2 years old 50 000 km and plenty of off road with no dramas. No lockers.
If you look at yahoo.groups/prado and you will see photos on there of rear diffs breaking. Too much flex of the pinion in the rear. Air lockers will help especially when one wheel is in the air and then it comes down. You will have to become a member to access it but
well worth it. It doesn't cost.
My opinion is raised
suspension but soft so it can flex and keep wheels on the ground. Example Lovells and Bilsteins is a very common set up on lcool.
120scruiser
509188
Reply By: SARocks - Thursday, Jun 21, 2007 at 14:11
When worked in NZ last winter warned about the Prado front diff. If the wheels are spinning in the snow and suddenly grip byebye front diff. As carefull as everybody was we blew 2. The workshop onsite kept a spare front diff on the shelf for Prado and Hilux.
248253
Reply By: Paps - Sunday, Jun 24, 2007 at 19:24
It sounds to me that they drive trains aren't keeping up with the engine output. And on another note, when I first started driving 4dwd 25 years ago, the system was to take it easy and only have an attack at terrain if you couldn't cruise up it. Watching footage of peaples trips into the Vic highcountry recently, everything seems to be hammer and tong. I have neve broken a thing. Series three Landrover with a 245 Hemi that I bought off my father, NG diesel pajero and now a GQ patrol. I wonder???
248803
Follow Up By: Member - Davoe (Nullagine) - Sunday, Jun 24, 2007 at 19:46
How did you fit the 245 in it is too long without cutting ito the Chasis?
509700
