1994 HZJ75 Troopy Hissing noise
Submitted: Thursday, Jun 21, 2007 at 14:14
dc
G'day,
I have a troopy (1HZ motor) and for the past 2 weeks, a hissing noise has developed at the front of the engine. Sounds like like around the fuel injection pump (but I do not know yet where the vacuum pump is so it could be that). The hissing noise is intermittent and changes with the revs. Anybody had a similar noise and can point me in the right direction?
Didier.
Reply By: Member - lyndon K (SA) - Thursday, Jun 21, 2007 at 21:22
It's not a loose air hose is it?
248351
Follow Up By: dc - Friday, Jun 22, 2007 at 08:42
That's what I am thinking about. Will check at the weekend. The vacuum pump is in the area the noise seems to come from. Cheers.
509295
Follow Up By: dc - Monday, Jun 25, 2007 at 10:42
Checked the vacuum pump and I cannot see anything wrong. However, the main vacuum line is not in good shape (rubber nearly perished) so I will replace it. Of cause, could not get the hissing noise to happen ;-)
509832
