Site Search
Section Image
80 series Air Con Problems
Submitted: Friday, May 02, 2003 at 15:44
tony
Hi all, I have an 80 series Turbo Diesel. Earlier today I was driving the car then stopped for about 30 minutes, when I started the car I had this loud squelling noise come from the motor I thought it was one of the belts, so I stopped the motor and checked and they seemed ok I restarted the motor and the noise was there for a short time and then stopped, I noticed that the air con has stopped, any ideas what I should look at next.
Thanks, Tony
Advertisement
ThreadID: 4693 Replies: 5
Views: 378 FollowUps: None
AnswerID: 18987   Submitted: Friday, May 02, 2003 at 16:47
Jack replied:
Hi Tony:
I would like to suggest it may be the belt(s) .. I currently have the same problem, and *will* get around to fixing it shortly. But I think my belts are also due for replacement. Try tightening them up. Mine "squeal" when cold .. give it a minute or two to warm up and all is well.
Jack
Reply 1 of 5
AnswerID: 18990   Submitted: Friday, May 02, 2003 at 17:11
Member - Chris (W.A.) replied:
Hi Tony, mine's had that problem before but when I replaced the belt realised it needed a new bearing also so you may want to check that. If the compressor has stopped altogether make sure there's no leaks as when empty it automatically will shut down.
RegardsLove the bush.
Chris
Reply 2 of 5
AnswerID: 19005   Submitted: Friday, May 02, 2003 at 20:33
Bob Y. - Qld replied:
Tony,
Aircon belt needs to be a lot tighter than the fan/alternator pair. Do as suggested and check idler pulley bearing, then re-tighten a/c belt. If you had bonnet up, someone could turn it on while you do the listening.
If a/c isn't working, check clutch is engaging/disengaging too. Might need a trip to a sparkie. We had a problematic 75 series that always squealed the aircon belts, with occasional lapses in performance. Think it had a prob. in compressor. Was pleased to get rid of it. Air is most important accessory out here, even before c/control. Hooroo...
Reply 3 of 5
AnswerID: 19012   Submitted: Friday, May 02, 2003 at 21:22
diamond replied:
all responses above would be a good place to start not sure if l/c air con run on idler pulley but most common squeel at work would be loose belts .as an air con belts is not under load all the time because of clutch they do need to be tighter as well as idler pulley might be ok when air of but once clutch engages more strain on belt there for on idler.when air clicks on you get a sudden strain on belt so if its a little loose if will give a squeel for a few seconds.another quick fix is to run some dry soap on yor belts.
Reply 4 of 5
Activities Index
Perth to Adelaide - 9 day tour Perth to Adelaide - 9 day tour
Perth - WA
The 9 Day Perth to Adelaide travels through the wheat belt of Western Australia to Esperance.
Porsche 911/996 Sports Car For A Day or Weekend Porsche 911/996 Sports Car For A Day or Weeke
Sydney - NSW
Drive a Porsche 911/996 for a day and experience the rear-mounted engine.
V8 Race Ute Challenge - SA V8 Race Ute Challenge - SA
Adelaide - SA
These utes raced in the national 2007 V8 Race series. They're the real deal.
Learn to Fly Fish at Oberon Learn to Fly Fish at Oberon
Blue Mountains - NSW
Enjoy a relaxing weekend at Oberon learning to fly fish.
Book Now - Things To Do
AnswerID: 19054   Submitted: Saturday, May 03, 2003 at 12:47
Member - Wherethefugawi replied:
ditto most of the above ..make sure the belt is tight and if it continues check to make sure the pullies are not worn out. A Vee belt must make contact with sides of the vee pulley only and not on the bottom. If you have a flat cog type belt and it continues you may have mechanical problem with the system or a refrigeration problem which will need to be checked out by qualified person.Cheers all
Reply 5 of 5
