Trailer Hitch
Submitted: Thursday, Jun 21, 2007 at 23:37
ThreadID: 46946 Views:2340 Replies:3 FollowUps:0
I want to change to a rubber block and am wondering if a 50mm ball hitch over rider can be changed without replacing the whole over rider plunger.
It looks like the front of the plunger has a pin that might knock out the hitch but a bit unsure.
Reply By: Member - MrBitchi (QLD) - Friday, Jun 22, 2007 at 07:46
Think you need to change the whole thing. Don't think you can buy the bits seperately.
AnswerID: 248403
Reply By: traveller2 - Friday, Jun 22, 2007 at 11:46
Carter Wesco make the bits and you can change the centre bit as the casting is standard, just has to be the same brand.
AnswerID: 248444
Reply By: Member - Phil G (SA) - Friday, Jun 22, 2007 at 14:25
Chard,
The Treg hitch is made in Adelaide (I think you're in Adelaide??). Take it down to Tregs at Underdale, and they will sort it out.
AnswerID: 248471
