USB chargers
Submitted: Friday, Jun 22, 2007 at 10:09
ThreadID: 46957 Views:1921 Replies:4 FollowUps:2
Hi all,
Search function didn't work for me so I ended up here.....
With the rise of USB car chargers for PDAs, GPSs, MP3 players, phones and lots of other stuff has anyone come across or made a multi plug charger?
Am I right in thinking they are all 5.5 volts?
Thanks,
NickR
Carpe Cerevisi
Reply By: Member - Sam (NSW) - Friday, Jun 22, 2007 at 10:44
Nick,
I know jaycar do have some multi-purpose car chargers for mp3 players/pdas/phones etc etc. Might not be what you are after though.
Sam.
AnswerID: 248435
Reply By: Chaz - Friday, Jun 22, 2007 at 11:44
Nick,
USB can charge anything below 5volts. I use the cigarette plug type for my Ipaq, mobile phone and Bluetooth GPS.
I haven’t tried it, but I can’t see why a small 4 port hub wouldn’t work to charge several devices at once.
AnswerID: 248442
Reply By: Member - Mike DID - Friday, Jun 22, 2007 at 12:34
The standard USB puts out 5.0 volts to a maximum of 0.5 amp (=500mA).
The device optionally communicates with the PC to set a lower current limit
AnswerID: 248452
Reply By: Member - Karl - Friday, Jun 22, 2007 at 13:32
Tandy and Dicks Smith (same owners/company) sells one that plugs into your lighter and then you plug your USB cable into it, this allows your to have one charge for different USB cables with the different size ends. Costa about $20 last time I looked.
Karl
AnswerID: 248460
Follow Up By: whyallacookie - Saturday, Jun 23, 2007 at 13:07
Has anyone else found these USb chargers to be next to useless. I have gone through several wireless mice that have been recharged via USb and none seem to last long (have replaced batteries etc etc)
The only one I have found any good is a Belkin that has a base station/cradle that has a 240v adaptor for the charging side of things.
Maybe you'd be better off buying a 240v inverter and charging them that way
FollowupID: 509486
Follow Up By: Russ n Sue - Saturday, Jun 23, 2007 at 14:30
That's what we did. We got a 240VAC to 5VDC plug pack and we run it via an inverter. It is capable of 3.0Amps but we plug only one device in at a time and these are usually never more than 500mA - 900mA.
A word of caution though, 240VAC inverters are quite capable of killing you so use them safely and watch for chaffed wires - a common occurrence in moving vehicles.
Russ.
FollowupID: 509500
