Removing ink from velour
Submitted: Friday, Jun 22, 2007 at 18:38
madfisher
Hi everyone, I have managed to get ink on my wifes pajs passenger
seat, anyone have any idea on how to remove it. As and aside I discovered to day petrol on a rag will remove tar from car carpets and duco
Cheers Pete
Reply By: Member QLD Steve & Lorraine Mc - Friday, Jun 22, 2007 at 18:45
Try Eucalyptus oil Pete, it removes most things.
Cheers Steve.
248511
Follow Up By: madfisher - Friday, Jun 22, 2007 at 20:02
thanks Steve its just biro ink so will try that as we have some
Cheers Pete
509410
Reply By: Member - Au-2 - Friday, Jun 22, 2007 at 18:56
Yeah madfisher, spray the stain with hair spray, leave it to dry, then rub the stain off with a clean cloth. You can buy a small can of H S at Woollies.
OzeSheila.
248515
Follow Up By: madfisher - Friday, Jun 22, 2007 at 20:03
Thanks for that handy hint.
Cheers Pete
509411
Follow Up By: Member No 1- Sunday, Jun 24, 2007 at 13:00
any left over yo can use on your hair
509626
Reply By: Member - barry F (NSW) - Friday, Jun 22, 2007 at 19:02
Hello madfisher, maybe I can help!! I own a family operated cleaning business & now & then we have the need to spot clean all sorts of stains from carpet,grease, food & coke etc. Go to your local dry cleaning
shop & see if you can cadge borrow or steal from him/her (got to be politically correct!!) a small amount of what is commonly called dry cleaning fluid. It is actually a product called Perchloroethylene We buy this product in a 15 litre container which for our commercial purpose last forever. It is normal procedure to at first try it on your fabric in an out of the way place just to ensure it does not have an adverse effect. Its a great product, but if you use it, (Carcinogenic) wear gloves, & if not in an open air situation, a respirator. I'am confident you will be happy with the result. best of luck
248517
Thank you Barry
Cheers Pete
509412
Follow Up By: babs - Saturday, Jun 23, 2007 at 05:20
I am in the restoration cleaning industry and can back up what Barry is saying, basically a solvent will remove the ink, make sure its a straight solvent though.
Forget the off the shelf products from your
supermarket, yeah some of them work but will damage your fabric in the process, with them you normally remove the stain only to be left with a different stain normally colour loss.
509448
Reply By: Member - Mike DID - Friday, Jun 22, 2007 at 19:15
If it's a
water-based ink as used in Inkjet Printers then Cloudy Ammonia will help - Coles have it in the household cleaning section.
248519
Reply By: Member - Mike DID - Friday, Jun 22, 2007 at 19:17
"I discovered to day petrol on a rag will remove tar from car carpets and duco"
- Yep, commercial Tar & Bug Remover is just a mixture of Turps and Cloudy Ammonia !
248521
Follow Up By: madfisher - Friday, Jun 22, 2007 at 20:04
Thank you Mike
Cheers Pete
509413
Reply By: Richard Kovac - Friday, Jun 22, 2007 at 21:36
whats velour?
248549
Follow Up By: Shane (QLD) - Saturday, Jun 23, 2007 at 15:07
The stuff between your ears !
509508
Follow Up By: Richard Kovac - Saturday, Jun 23, 2007 at 15:19
oh he still around...LOL
509511
Follow Up By: Richard Kovac - Monday, Jun 25, 2007 at 21:13
Hey u
Called yer mate at the pub... had a laugh..
510016
Reply By: Truckster (Vic) - Saturday, Jun 23, 2007 at 00:35
what ever you try, try it out of sight first, so if the cleaner stuffs up your
seat, you can try something else, before leaving a big mark where the ink is right in plain sight.
I used Big Kevs stuff a friend had to get Bic pen ink out of the GQ velour seats.
248572
Follow Up By: madfisher - Saturday, Jun 23, 2007 at 14:12
Thanks for that truckster, it had to be SWMBO
seat.
Cheers Pete
509496
Reply By: pauljohnston - Saturday, Jun 23, 2007 at 21:04
Plain old metho works
well. If that doesn't work try the drycleaning fluid, or if you have some shelllite or white spirits its the same stuff. (they all run through my coleman lantern the same).
Good luck.
Paul.
248681
