Garmin GPS 7200 & others
Submitted: Friday, Jun 22, 2007 at 19:56
ThreadID: 46981 Views:3229 Replies:8 FollowUps:5
Evening all,
I have done the detail and reviewed the options of the Garmin GPS series with the view to using it stand alone both for the bush and town.
The expert who was rather short on tech detail enlightened me to the fact that even after spending close to $2000 the GPS would still need a laptop connected to deliver moving maps. (Oziexplore & Toppo both discussed.)
After due consideration I have opted to use standard paper topographic maps. Simple, robust and not reliant on any high tech constraints.
The mere fact that a laptop is required to support the GPS is rather delicate and not fit for purpose in the bush.
Anyway that is enough.
Reply By: Member - Doug T (W.A) - Friday, Jun 22, 2007 at 20:32
What a load of BS he told you, the bloody mapping software on the GPS moves as you travel, and the best setting for anyone else interested is TRACK UP , then as you travel the road the heading is always to the top of the screen no matter what bearing your on , that then also puts a street that will be on your right in real time will also be on the right side of the GPS screen
Doug
AnswerID: 248535
Follow Up By: blue one - Saturday, Jun 23, 2007 at 08:55
Yes Doug I had a low level of confidence in the "ex-spurt's" advise. So what you are saying is that with Track Up the GPS can stand alone?
Can Track Up be used around town as well as in the bush?
If so can it run on a Navman 510 or do I have to purchase a Garmin?
Thanks for your robust interest.
FollowupID: 509455
Follow Up By: Bonz (Vic) - Sunday, Jun 24, 2007 at 21:14
I beg to differ, TRACK UP is a female addition to the time honoured NORTH UP option preferred by all REAL MEN, that is preferred until the men got IN TOUCH with their female sides, I like the female side
FollowupID: 509745
Reply By: Member - Doug T (W.A) - Saturday, Jun 23, 2007 at 09:18
No No No .......track up is not some software you run in the GPS it is a setting , with TRACK UP the direction you are heading will always be toward the top of the screen, so the little cursor that shows your position will be pointing toward the top, so if you do a complete 360deg turn the map on the screen will rotate too, with this setting East might well be at the bottom of the screen , same as looking at a paper map,
If you have the GPS setting on NORTH UP the map will not rotate and the cursor will if your heading West move across the screen from right to left and could be confusing ....umm err ....to a woman trying to read it ....( just joking Ladies ) Thus making a road that will be a right turn would appear to head up toward the top of the screen instead of to the right of the screen as you would see it out through the windscreen,
And the answer to your question is YES the mapping software that will be already installed on the Garmin GPS will be as you call it stand alone , it will scroll down the screen as you progress along the road, the Xroad as you traverse past it will then disappear off the screen and the next part of the road will continually appear,
You can add another type of software called Tracks4Australia that will only work in a Garmin but don't worry about that until you become used to using the unit. You can see a section of T4A that I have used for a Background in my GPS webpage,
members.westnet.com.au/dtilley/maps.htm scroll down untill there is less text for a better view
And as for Navman , forget you even seen one .
Feel free to ask for aid anytime you like .
Doug
AnswerID: 248594
Follow Up By: Member - Doug T (W.A) - Saturday, Jun 23, 2007 at 09:31
Oh and the brightness of that background is not as it is on a GPS , that is a screen shot JPG picture and I dulled it down to make the text stand out more.
Doug
FollowupID: 509459
Reply By: blue one - Saturday, Jun 23, 2007 at 09:41
Ok Doug,
As the 7200 is rather expensive which GPS would be more cost effective? I want one for use in a Patrol for town and bush.
AnswerID: 248596
Follow Up By: Bonz (Vic) - Sunday, Jun 24, 2007 at 21:16
Blue one I have a Garmin GPSMap 60 CS (now a CSx) and it will do all you need to do for a measly 1300 (ish) with the maps installed and running town or country or bush. I have City Navigator maps theyre great.
FollowupID: 509748
Reply By: blue one - Saturday, Jun 23, 2007 at 10:00
As the unit is standalone are there any tricks such as larger SD card etc for storage of maps and processing speeds?
AnswerID: 248600
Reply By: Gone Bush (WA) - Saturday, Jun 23, 2007 at 11:07
I have the Garmin Nuvi 660. I don't know the difference, in detail, between mine and the 720. I agree with Doug, stay away from Navman (used to sell all brands which is why I chose the 660). By the looks of Doug's website and postings he is much more knowledgable on these things than me. I am just starting to look at loading T4A and Camps4 locations.
I would listen to Doug on these matters (except his opinion of Uniden UHFs .... lol)
AnswerID: 248605
Reply By: Member - Navigator 1 - Saturday, Jun 23, 2007 at 16:18
Hi blue one
I have the Garmin 275C with the advantage of a bigger screen and excellent clarity. To me the only improvement to this unit would be a touch screen. The main disadvantage of this one, apart from the price, is the card. It is a dedicated Garmin card and expensive.
Doug, I know of one lady who can read a map/gps any which way and we must always remember that the ladies can multitask, unlike many of the men folk.
Nav 1
The outback calls
AnswerID: 248637
Follow Up By: Member - Doug T (W.A) - Sunday, Jun 24, 2007 at 14:09
Nav 1
Are you stickin' up for the ladies boyyyy , well you better have a look at this , and if this link don't work the 2nd will but you will have to go right to the bottom of the page and click it there ....
Men's Rules I thinks you will be using the link below by the look of this
members.westnet.com.au/dtilley/gps.htm
FollowupID: 509637
Reply By: Member - Prickle (SA) - Sunday, Jun 24, 2007 at 10:39
Blue One
I have just purchased a Garmin Quest to replace my Garmin Plus ii.
It will do what the old one will and more.
Appears to be good for both town and outback trips.
Still working it out, but I am sure it will suit my needs.
Cost me about $800
Russ
Life-often hell but never boring.
AnswerID: 248736
Reply By: blue one - Sunday, Jul 01, 2007 at 18:33
Thank you very much to all,
Your advice has been invaluable
I still need convincing about spending $ on a GPS.
AnswerID: 250183
