Help finding OziExplorer topo maps
Submitted: Monday, Jun 25, 2007 at 00:16
Urshtnme
Hey guys, I've spent a fortune on OziExplorer and its maps plus the PDA to put it on but I just can't find any decent topographical maps for OziExplorer.
Anyone got any idea where I can get them for WA?
Reply By: Richard Kovac - Monday, Jun 25, 2007 at 00:45
Urshtnme
This site Site Link
cover SW Site Link
248862
Follow Up By: Urshtnme - Monday, Jun 25, 2007 at 10:16
Cheers Richard, just adding them to my wish list for when I get home. Going to be doing more South West WA trips after getting back home from
Broome.
509823
Reply By: Richard Kovac - Monday, Jun 25, 2007 at 00:48
You may also need www.oziexplorer3.com/img2ozf/img2ozf.html
248863
Follow Up By: Member - Andrew (QLD) - Monday, Jun 25, 2007 at 07:49
Why? Isn't every mapset shown there available in Ozf2, Ozf3 or ECW format? :-)
Andr
509799
Follow Up By: The Explorer - Monday, Jun 25, 2007 at 09:47
Yes you are correct - but Richard did say "may also need" so we can let him off on a technicality. I always prefer to change even ecw to ozf format anyway, but there is no real reason as I am lead to believe ECW files work fine. Ozf may just load a tad faster (especially the bigger size files).
509818
Reply By: The Explorer - Monday, Jun 25, 2007 at 09:59
Yes, as Richard points out the best currenty available didgital topos for sections of WA are available from the ExplorOz
shop. I have heard, from a very reliable source (Me), that the
Pilbara 50K map set (~400 maps) will be available in a month or two for similar price to the Kimbelery 50K set - so keep your eys and ears open for release - it should be announced in Exploroz newsletter.
The maps dont show every track in existence as some have not been undated for a while. This is especially true of the South West ones (50K and 25k) which are circa late 1980's to early 1990's at best and will not be updated by state government as they now just deal in electronic data which they sell seperately i.e. cadastral data, contours etc for GIS/CAD users.
Kimberley 50K is better with some maps being 2005 editions. Whatever the case, any map is better than no map (but I may be biased in my view:)
248891
Follow Up By: Richard Kovac - Monday, Jun 25, 2007 at 21:02
I will keep an eye out
Richard
510009
Reply By: obee - Monday, Jun 25, 2007 at 10:33
if the maps you got are of several varietys that ozi can use they will be converted to ozi format when you import them. Not load but use the "import" option under "file"
I bought the natmap series and they work fine.
Owen
248900
Reply By: Member - Doug T (W.A) - Monday, Jun 25, 2007 at 13:29
What make of PDS is it
Raster maps are a copy of the paper maps , and when zoomed in to close the resolution degrades to a point where it becomes unreadable, I find T4A is a good set but you need a Garmin unit to run it, OziExplorer I have too but don't use it anymore, one might as
well go get a paper map and the Rasters look the same ,
Now that CD Richard linked too, the Raster 50K South West WA would be ok but to get the whole of Australia would cost a small fortune
248937
Follow Up By: The Explorer - Monday, Jun 25, 2007 at 15:13
Hello Doug - Firstly T4A uses same data as the 250K maps so using the raster set with Oziexplorer will have same detail as the t4A you use. True, the t4a are in vector format and you can zoom in and screen stays "pretty" (apart from increased jagged nature of linear features such as rivers and roads due to scale of data capture) - but you are not really gaining anything over using the raster 250K set, and neither will have the detail that is found on larger scale maps (eg 50K or 25K).
There is no point in zooming in past a certain point on raster images anyway - no extra detail will be revealed. You dont buy a paper map and then hold it against your face in the vain hope of seeing something extra which is what you are doing if you zoom in too close with a raster image...so why do it? The advantage of having raster images for use with OziExplorer is
well documented and they have uses that paper maps dont (and visa versa).
While discussiing vector mapping is off topic on this thread just like to state that if you did want decent vector mapping for a GPS (and werent afraid to actually pay some money), Magellan mapping is probably better option than Garmin anyway - DiscoverAus has street level data (unlike t4A and shonky) in addition to (at least the WA section) having roads and tracks as found on the 25K series of raster maps.
509884
Follow Up By: The Explorer - Monday, Jun 25, 2007 at 15:22
PS - the digital versions of the various map series available on DVD are far cheaper than purchasing indvidual map sheets if you plan on getting a few. For example the
Kimberley 50K DVD contains 483 maps and costs about $120. For $120 you could only buy ~12 paper maps:( With the digital version you can also just print out areas you want as
well - very handy.
509888
