Alternator used for welding
Submitted: Monday, Jun 25, 2007 at 14:25
ThreadID: 47058 Views:2386 Replies:4 FollowUps:8
Is it possible to buy a alternator that you can mount to use as a welder?
I was talking to a guy the other day, that remembered years ago there was such a thing, could this also perform as an alternator on a car as well(100 series) ?
Cheers Steve.
Reply By: GoneTroppo Member (FNQ) - Monday, Jun 25, 2007 at 14:32
You mean one of these
www.mobi-arc.com/faq.htm
AnswerID: 248948
Follow Up By: Steve from Top End Explorer Tours - Monday, Jun 25, 2007 at 14:44
what an ingenious device.
Steve.
FollowupID: 509873
Follow Up By: Stu050 - Monday, Jun 25, 2007 at 17:20
Or one of these;
www.unipower.com.au/index2.asp
Made in WA
FollowupID: 509922
Follow Up By: disco driver - Monday, Jun 25, 2007 at 18:52
There used to be a product called "Auto-Arc which used a re worked alternator to provide welding, 240V and Battery charging facilities.
I note that Unipower looks just it and does the same thing.
Mate had an Auto-Arc on his work shop Landrover, magic thing to weld with, and enough grunt to run a 9" angle grinder and some lights,240V, at the same time.
No idea on price but if you're going remote it would be worth investigating.
Disco
FollowupID: 509946
Reply By: Redback - Monday, Jun 25, 2007 at 15:11
The new generation Ford Explorers alternater can be used for welding so i was told.
They are apparently over 300watts, maybe even close to 400
AnswerID: 248961
Follow Up By: Member - Mike DID - Monday, Jun 25, 2007 at 20:32
The current Pajero Alternator is 1500 watts - 12 volts x 130 amps = 1500 watts.
But it's no use for welding - you need 24 volts to weld.
FollowupID: 509990
Follow Up By: Redback - Monday, Jun 25, 2007 at 21:07
OK it's 300 to 400amps then, sorry, still your able to weld with it.
FollowupID: 510011
Follow Up By: Axel [ the real one ] - Monday, Jun 25, 2007 at 22:14
Even the one you drowned had the capabillity to supply enough amps for welding , just a little matter of getting it up to 24v , 2x 12v batts and its easy as. , seems to me easier than at home as not as much "setup "variables , just steady welding.
FollowupID: 510035
Reply By: CLC50 - Monday, Jun 25, 2007 at 15:25
If you are really in trouble just use Two or three Batteries
see Link
Check out the Link
AnswerID: 248964
Follow Up By: CLC50 - Monday, Jun 25, 2007 at 15:26
www.4x4wire.com/isuzu/minutemods/welder/
FollowupID: 509891
Follow Up By: Member - lyndon K (SA) - Monday, Jun 25, 2007 at 22:31
Yep, i just use my batts to weld with, you need the hand piece,glass,rods,jumper leads. that all
Now is the only time you own
Decide now what you will,
Place faith not in tomorrow
FollowupID: 510038
Reply By: Steve from Top End Explorer Tours - Thursday, Jun 28, 2007 at 06:38
There are some great ideas, thanks.
Cheers Steve.
AnswerID: 249596
