Bye bye battery me thinks
Submitted: Monday, Jun 25, 2007 at 14:31
kimprado
Just lifted the bonnet after two weeks, and found the HD battery full of cr*p on the terminals and cross bar (big time).
Water levels are ok. Anyone come accross this before?
I might add that the battery is four years old and has taken a bit of rough treatment in that time.
Kim
Reply By: Wayne-o (Pilbara WA) - Monday, Jun 25, 2007 at 14:48
KIM,
i found this to be the case on my old hilux, so i pulled the battery out, washed with boiling
water, filed the terminal to a shiny finish, recrimped the conectors, and it was good for,
well until i sold it.
good luck
Wayne-o
248951
Follow Up By: kimprado - Monday, Jun 25, 2007 at 16:10
Wayne
Thanks. Already washed it off and will clean up the terminals tomorrow morning and re-grease. I think the poor old thing is terminal (bit like me).
Kim
509907
Reply By: Member - Noldi (WA) - Monday, Jun 25, 2007 at 15:11
I have had the same (white fury masses) on batteries in the past. I was told hot
water with a spoonful of Bi Carb of soda poured over the terminals then rince off with cold
water. Seemed to work for me. Don't remember if the batteries packed up shortly after or not but its worth a go.
Rgds
Ian
248960
Follow Up By: Member - Oldplodder (QLD) - Monday, Jun 25, 2007 at 16:17
Hot / warm
water & bi-carb works for me too.
Havn't overfilled the battery at some stage and some boiled or got shaken out?
Caps vary in quality, some have good labryinth seals inside and some don't.
509909
Reply By: Member - John L G - Monday, Jun 25, 2007 at 15:37
Soda
water works a treat...
248969
Follow Up By: Wayne-o (Pilbara WA) - Monday, Jun 25, 2007 at 16:04
specially with a dash of 12 yr old scotch.
509904
Follow Up By: Stu050 - Monday, Jun 25, 2007 at 17:16
Sacrilege!!!!!!
12 yr old scotch should be drunk with the head reverently bared, while ensconced on the
seat of choice.:))
509921
Follow Up By: Member - Glenn D (NSW) - Monday, Jun 25, 2007 at 20:38
Nice rig Pics Wayne o ,
Your Mrs with the GT ?
My Mrs got things messed up when over seas and bought a bottle of ' Glenfiddich ' 30 yr old for $40 , almost cried when I drank it but held back , LOL
Glenn.
509993
Follow Up By: Wayne-o (Pilbara WA) - Tuesday, Jun 26, 2007 at 10:40
Glenn D
Yeah she hooked it, but i spent the next 40 mins draggin it to the surface, but of course she will take all the glory. LOL
Cheers.
510140
Reply By: Dasher_Syme - Monday, Jun 25, 2007 at 17:32
I would also check your charging circuit as the fur can be a result of too much zoom!
Should be around 13.8 volts when at idle too much more will grow fur!
dasher
249002
Reply By: Sand Man (SA) - Tuesday, Jun 26, 2007 at 00:45
Kim,
A fairly normal occurrence on most vehicle batteries, over time.
As mentioned, a little bi-carb of soda mixed in warm
water will neutralise the acid.
Clean the terminals and cable clamps with a wire brush and coat the terminals with vaseline before reconnecting. I have also found a pair of impregnated felt pads (green and red) available from Kmart, Super Cheap, Repco, etc. also helps to stop the buildup from reoccurring. You can also buy a cheap wire brush cleaner from the same
places which are specifically designed for battery terminals and cable clamps.
249163
