Fuel additives
Submitted: Monday, Jun 25, 2007 at 15:08
ThreadID: 47064 Views:1910 Replies:5 FollowUps:4
Do any of these work and are they cost effective
Reply By: Wayne-o (Pilbara WA) - Monday, Jun 25, 2007 at 15:10
If you ask Roothy, he swears by FLASH LUBE diesel treatment....
AnswerID: 248959
Follow Up By: Member -Signman - Monday, Jun 25, 2007 at 15:40
Yea- but he also swears by XXXX........
FollowupID: 509895
Follow Up By: Wayne-o (Pilbara WA) - Monday, Jun 25, 2007 at 16:03
True, and i think ive seen a can or two of VB in his hand before......eeeewwww....LOL
Wayne-o
FollowupID: 509903
Follow Up By: Kev M (NSW) - Monday, Jun 25, 2007 at 16:11
And Boags :)
Kev
Russell Coight:
FollowupID: 509908
Follow Up By: Wayne-o (Pilbara WA) - Monday, Jun 25, 2007 at 16:23
Not to mention his Cooper tires......OOps, shouldnt have said that should I???
FollowupID: 509913
Reply By: madfisher - Monday, Jun 25, 2007 at 15:43
When I worked driving Concrete Aggis The boss tried various diesel conditioners , because of the constant ilding of the trucks. We only found two that worked in reducing smoke etc. so some do and some dont.
Cheers Pete
AnswerID: 248970
Reply By: Member - John G- Monday, Jun 25, 2007 at 17:37
I've used Flash Lube diesel conditioner.
When I first used it I checked fuel consumption around town over about 1200km - got about 0.5 litre / 100km improvement on fuel economy.
Doesn't seem to make any difference when towing, but conditions change so much day to day it's pretty hard to make reliable comparisons.
At the end of the day, 0.5 litres/100km is a marginal improvement. Whether it keeps things clean inside the engine I don't know.
John G
AnswerID: 249004
Reply By: obee - Monday, Jun 25, 2007 at 20:57
I get a bottle now and then and put it through 50mm at a time as recommended. the important thing from my point of view is that it dissolves any moisture in the tank. Moisture in the tank leads to algea growing and blocking up the works. It cant do the injectors any harm either, removing build up of whatever on the spraying ports. Thats if they really do. I have seen improvements to a smoky motor but never noticed any fuel economy improvements.
I only use it every year or so its cost effective, yeah.
Owen
AnswerID: 249092
Reply By: Axel [ the real one ] - Monday, Jun 25, 2007 at 21:14
Heads or Tails , yes or no , cost effective ,yes if they work ,no if they dont , been using the Moreys diesel conditioner , does it work? like to think so , no smoke at start up and no smoke at planting the right foot , is my fuel economy better ? just a tad but realy not measurable enough to say "go and use ect ect" , do know though that when I dont use it the 80 seems to be "not quite itself " as per power and smoke.
AnswerID: 249101
