FollowupID: 12073 Submitted:
Tuesday, May 06, 2003 at 10:14
Member - Kevin (NSW/ACT) posted:
Totally agree on quality of after sales service. I have had my unit in for 6 months or so and recently noticed that the main battery seemed to be brought into the charging system more often than before. A quick call to Rod had me checking the cells with a hydrometer and I found one to be very poor. Battery voltage appeared okay but with the crook cell it doesn't hold the required charge level hence the RDC12M bringing it back into charge all the time. Better to know the battery is on the way out before it fails I guess. Now to see if Nissan will replace the battery under warranty! - first indications are not promising as adding a dual battery system is 'modifying' the standard system which voids the warranty.Kevin - sitting here, thinking of there
2002 GU Patrol ST 4.2TD
2000 15' Supreme Getaway
