Flags on LC100 without a bullbar
Submitted: Monday, Jun 25, 2007 at 21:34
dev123
We're off to "do the Simpson" later this year in a LC100 TD that does not have a bullbar. I've read plenty on this site and in other
places about using a flag on a pole to warn on comming vehicles. My question is how are these attached when there is no bullbar? I'd be interested in any ideas.
Please don't say tape it to the side of the passengers door etc (as per posts in the archives) as this is not an option on a new vehicle. :-)
Thanks in advance for any useful ideas.
Dev
Reply By: Pete and Lez S.A. - Monday, Jun 25, 2007 at 22:55
Hi Dev, Before I fitted a bullbar to
mine I had a piece of flat steel about 50mm wide and had a kink put in it, and attatched it to the front recovery point mounting bolts. The bracket extended out past the bumper bar with a hole drilled thru the end to fit the flag pole to, it had a threaded end on it so was easy to bolt to the flat steel. depending on what you are using for a flag pole you could still attatch it to the piece of flat steel. This piece of steel is reasonably long so it was about 13mm thick for strength.
Cheers Peter and Lez
249131
Follow Up By: dev123 - Tuesday, Jun 26, 2007 at 08:52
Thanks for the idea - I'll have a look at doing something similar.
Dev
510107
Reply By: lc_120man - Monday, Jun 25, 2007 at 23:04
Roof rack/or roof bars...
249135
Reply By: Member - Jiarna (NT) - Monday, Jun 25, 2007 at 23:11
If you are in a convoy, and have UHF to communicate with the rest of the convoy, just stay in the middle. Only the lead vehicle really needs a flag, as everyone else will know about oncoming traffic from the leader's yell over the UHF.
Have fun, it's a great trip.
249139
Follow Up By: dev123 - Tuesday, Jun 26, 2007 at 08:53
I like the idea of being in the middle....
Unfortunately none of the other vehicles have bull bars either so they are facing a similar dilemma.
510108
Reply By: Member - Phil G (SA) - Tuesday, Jun 26, 2007 at 02:23
On a Prado, I drilled a 3/4" hole through the top of the bumper directly in line with a metal upright adjacent to the chassis mount, and inside the bumper. I cable tied a length of 25mm RHS to the metal upright. Then I was able to slip a sandflag through the hole, and it stayed there nicely. For a sandflag, I used the 3/4"
orange electrical conduit, with the bottom metre reinforced by shoving some dowel up the middle. I used the sleeve on the conduit to make a 2 piece pole. I kept the hole covered with a grommet.
249170
Follow Up By: Member - Ruth D (QLD) - Tuesday, Jun 26, 2007 at 09:25
Good idea - it was lovely out there last week - frosty though.
510124
Reply By: Member - Greydemon (WA) - Tuesday, Jun 26, 2007 at 12:47
I have the same problem, my UHF ariel uses a Z shaped bracket which is held by an (existing) bolt down the side of the bonnet, there are usually a couple to choose from. I plan to get a second one on the other side and use that to mount the flag. I'll probably use the base of a cheap second hand ariel and lash an old fishing rod to it for height. It can then be easily unscrewed and taken apart. I'll probably use a bit of gaffer tape where the two parts of the rod are joined just for peace of mind.
249246
Follow Up By: Member - Greydemon (WA) - Tuesday, Jun 26, 2007 at 13:16
ariel ????? Make that 'aerial', or perhaps 'antenna'.
510171
