Have I got this right ? Lightforce Lights
Submitted: Monday, Jun 25, 2007 at 22:51
Outnabout David (SA)
Ok need some help to confirm what I think is right.
As far as lighforce goes there is
240 Blitz which I think has an adjustment for focal length or spread maybe which you can then put plain crystal blue covers on.
240 XGT which has fixed focal lenght to which you put a combo cover on get a spread beam.
Am I right or wrong here?
Why would you pay extra for a fixed length light ? or am I missing something
Thanks in advance. Just want to by the lights once.!
Reply By: Member - John (Vic) - Monday, Jun 25, 2007 at 22:54
Yep correct.
249129
Reply By: Member - Lloyd B (NSW) - Monday, Jun 25, 2007 at 22:57
I think the XGT is a H.I.D. light.
249133
Follow Up By: Member - John (Vic) - Monday, Jun 25, 2007 at 23:00
Nope the XGT is not a HID.
LF have a HID that looks the same as the XGT in its case but obviously different bulb and guts etc.
510042
Follow Up By: Pete and Lez S.A. - Monday, Jun 25, 2007 at 23:02
So the XGT can be a HID, but you can buy the Blitz in the XGT housing, this version is also more theft proof.
510043
Follow Up By: Member - John (Vic) - Monday, Jun 25, 2007 at 23:09
Hiya Peter hope all is going
well with you.
The XGT and the HID are two different lights in every respect other than they share the same outside case or housing, they look the same to the casual observer and until you look at the rear of the light which will say either HID or XGT you can't really tell them apart until you turn them on :-)
My understanding is the 240 Blitz is not available in HID but I think it does have some sort of beam adjustment by screwing the reflector housing in or out.
I agree with your comment about the XGT being a bit more secure as I believe you can screw the reflector off the Blitz relatively easily.
I own XGT's so we need a Blitz owner to confirm that.
510046
Follow Up By: Member - John (Vic) - Monday, Jun 25, 2007 at 23:11
Have a look here www.lightforce.net.au/driving.html for all the info on the range.
510047
Follow Up By: Pete and Lez S.A. - Monday, Jun 25, 2007 at 23:19
Going
well thank you John, By more theft proof I was meaning they, XGT type, are more difficult to remove from the bull bar, you need two different sized spanners to remove them. I guess the crims know that anyway.
510051
Follow Up By: Member - JohnR (Vic)&Moses - Tuesday, Jun 26, 2007 at 06:42
Pete, looking forward to catching up at Warraweena. It is relatively easy to theft proof the Blitz lights or at least as much as anything else on a bullbar. Need a hammer, the right sized punch, and a crow bar, and sockets the right size,
I find the 240 Blitz great that I can rotate to a large spread beam in slower conditions round corners and over ridges.
510074
Reply By: Pete and Lez S.A. - Monday, Jun 25, 2007 at 22:59
Hi Dave, I think the blitz is only a spot, also requiring a combo cover to get a spread beam pattern. Thats what I did but I wouldnt bother with the combo cover, two spots were much better.
Cheers Peter and Lez
249134
Follow Up By: Drew - Karratha - Tuesday, Jun 26, 2007 at 15:14
and 3 are better again - one to the left, one to the right, and one right down the guts!!
510194
Reply By: Derek from Affordable Batteries & Radiators - Monday, Jun 25, 2007 at 23:10
Hi Guys
The Blitz rotate similar to a mag light to adjust the beam.
The XGT are touring lights, similar to a fixed euro beam.
Derek.
249138
Reply By: Markymark - Monday, Jun 25, 2007 at 23:35
I have the Blitz. As mentioned they do rotate which adjusts the beam but it makes it hollow on the inside, just like winding out a mag torch as Derek said. This looks crap too by the way. If you want spread it is best to but the combo cover which is what I did. When travelling tight twisty bush roads the pencils weren't very good but with the combo I was happy.
With the rotate thing, it you keep twisting you will spin them off completely. I have an old Lightforce 140 hand held spotty and having been using one of the 240 reflectors as they're so easy to change and WOW, what a difference in light!
No the Blitz didn't come in HID.
Mark.
249142
Reply By: Outnabout David (SA) - Monday, Jun 25, 2007 at 23:49
OK thanks for your replies.
Now next question to all those 80 series owners with ARB bull bars and 240's . Do both types fit?
249145
Follow Up By: Drew - Karratha - Tuesday, Jun 26, 2007 at 11:44
XGT's do not fit, Blitz do. I have 3 on the ARB bar of my 80 (same bar as in your picture above). If you send me your email I can send a photo of how I set them up.
Drew
510152
Follow Up By: Outnabout David (SA) - Tuesday, Jun 26, 2007 at 21:30
Email is djs56 at optusnet dot com dot au
510279
Reply By: Member - Doug T (W.A) - Tuesday, Jun 26, 2007 at 00:07
Read www.lightforce.net.au/
249151
Reply By: Member - BUNDY BOY (WA) - Tuesday, Jun 26, 2007 at 08:39
David........240 blitz..& xgts...same internals.and lenses....blitz.can be rotated from pencil to spread..xgts...ar a fixed non adjustable pencil........clip on covers in clear and coloured....spread and duel fit both lights....xgts outer body and mounting are same as .....HID version.......a lot sturdier...and robust than the BLITZ......XGTS can be upgraded at a later date with HID inserts and bulbs if u so require......BLITZ can not............................have heard of BLITZ being unwind able for adjustment.......unwinding them selves on corrugated roads and u wouldn't know toll u stopped that you had lost a light ........and finding a replacement in the out back would prove ....ni on impossible and costly........eg i am upgrading to .......XGTS....with light blue covers pencil light only for the whiter light ....for straight line distance only .......have a set of nane spreads set at angle for fog line and bush lighting ....
Cheers BUNDY
249193
Follow Up By: Drew - Karratha - Tuesday, Jun 26, 2007 at 12:54
What is the benefit of the blue covers over the clear ones??
510165
Follow Up By: Member - Roachie (SA) - Tuesday, Jun 26, 2007 at 13:14
Blue covers make the light appear to be whiter.
I have previously read somewhere that you can get a kit or something to upgrade XGTs to HID. I was interested in doing this, so I phoned Lightforce in
Adelaide and they said they do not supply such gear......so I don't know where you would get the stuff if the manufacturer doesn't supply it.
If anybody has actually done upgrade, could you let us know the details please.
510169
Follow Up By: Drew - Karratha - Tuesday, Jun 26, 2007 at 15:12
Thanks Roachie, but wouldnt the blue covers actually lower the light output? - Or does the now whiter light make it appear brighter?? I have wanted to buy some blue covers for a while, but only if they will improve the vision...
510193
Follow Up By: Member - Roachie (SA) - Tuesday, Jun 26, 2007 at 16:52
Hard to say for sure Drew. I bought the blue covers because I'm running Xenonoz HID inserts in my main headlights. These are very white and with the standard clear or difuser covers on the XGTs, the spotties looked REALLY yellow by comparison.
Now, with the blue covers, the difference isn't anywhere near as noticeable. I would still love to be able to afford at least one Lightforce HID (and leave the other one as an XGT).....dream-on....hahaha
510211
Follow Up By: Member - John (Vic) - Tuesday, Jun 26, 2007 at 18:42
Drew use the crystal blue LF covers and yes they do make the light whiter and clearer.
No they don't seem to lower output actually makes them better in my view.
I to was under the impression that you could not upgrade the XGT guts to HID.
510237
Reply By: Gossy - Tuesday, Jun 26, 2007 at 09:55
big
forum so not reading it all :)
I have XGT so here we go.
Same external as the HID but uses a 100W globe. They come out of the box as both spots. Need to buy a cover which gives you the spread. This spread still puts a 'dot' down the road though due to it's intensity.
If you have room to fit them then I highly recommened them. For "bang for your bucks" you cant get better.
The spread I particularly like as it doesn't put light where not needed (as per normal glass fronted lights like IPF, Cibie etc). You can test this by looking at spread beams against a wall. There is light going up to the roof etc.
The lightforce attachment gives a definite 'line' across the road directing all your light power where you need it.
enjoy,
249216
