Mazda T3500 4WD???
Submitted: Tuesday, Jun 26, 2007 at 13:25
Member -Signman
I know there's a broad range of users here- who have driven a wide range of vehicles !! So- has anyone had anything to do with Mazda T3500 (specifically the 4WD derivative) ???
Any major (or minor) inherent problems???
Reply By: Member - Tour Boy- Tuesday, Jun 26, 2007 at 17:02
HI, driven both buses and 4wds.
All noisy, gutless, smokey, and thirsty even with the split diff.
If you can find one, there are some 6 cyl versions but rare as. I've only driven 4 cyl versions.
TB
249278
Follow Up By: Sarg - Tuesday, Jun 26, 2007 at 22:16
You forgot to add that it will shake your teeth out while compressing your vertebrate at the same time.
510299
Reply By: Eric Experience - Tuesday, Jun 26, 2007 at 22:16
Signman.
The mazda 4x4 has the motor raised up to allow for the front diff, this creates a large lump between the driver and passenger, The noise of the motor makes conversation difficult. If you are using it as a work vehicle it is ok but if you are thinking mobile home the noise would make it unpleasant. The Canter is a much better camper. Eric.
249365
