help on side affect
Submitted: Tuesday, Jun 26, 2007 at 20:55
cruser
Hi there i need help in regarding blocking off the exhaust gas recirculation pipe on my 100s landcriuser. Is there any long term damage or im helping the motor to letting clean air in to the intake manifold.?
Reply By: Doggy Tease - Tuesday, Jun 26, 2007 at 21:35
Try the Landcruiser site mate,,,,they would have much more technical and specific answers.... llcool.org...........i think, or something to that effect at least...:)
meow.
rick.
249352
Follow Up By: cruser - Thursday, Jun 28, 2007 at 19:08
doggy
thanks for that i have read this article from llcool and it does make sense to remove it.
thanks again
510709
Reply By: Member - Phil G (SA) - Wednesday, Jun 27, 2007 at 09:28
LCOOL article on EGR
My 79series 1HD-FTE engine was underperforming a bit. I cleaned all that carbon out of the intake, and doctored the EGR, and it goes like new again. Starts first click, fuel consumption better, and sounds sweet. That was almost 2 years ago. From what I've been told, theres no negatives to doing this.
249406
Follow Up By: cruser - Thursday, Jun 28, 2007 at 19:13
thanks for that now i know that im doing the right thing to block it off. can you tell me if you only blocked the vacum pipes or gone all the way and removed the recirculation pipe as
well ?
thanks mark
510712
Follow Up By: Member - Phil G (SA) - Thursday, Jun 28, 2007 at 19:30
I left the pipe alone. Just did what was suggested in the LCOOL article - block off the vacuum where they tell you to - I used a tight fitting nail, and I also drilled a fine hole in the 3-way connecter nearest the EGR, to ensure that there was no vacuum getting thru to the EGR.
510716
Reply By: cruser - Thursday, Jun 28, 2007 at 19:37
thanks looks like i will do the same
249705
