AnswerID: 19105 Submitted: Sunday, May 04, 2003 at 19:18
David N.
replied:
I also have a mint TD42 1991 model, very low klms!
It may be Airconditioner oil...I had an oily smell from the aircon last year and found the gas was also a bit low.(I thought it might have been diesel too.)
I pulled the fan/ evaporator box apart and found a leaky "o" ring due to a bit of corrosion on one of the gas lines. (It's always wet due to condensation- there was obvious airconditioner oil in the airbox)
I pulled the fitting apart, polished the surface with 600 grade sandpaper and fitted a new "o" ring and it's as good as new. Hasn't leaked a drop or any gas since...
Reply 2 of 3
FollowupID: 12009 Submitted:
Sunday, May 04, 2003 at 19:48
GPA posted:
thanks David - that sounds like a good tip. I'll be sure to check it out.
PS . The previous owner never had the GQ off the road in it's first 11yrs (119,000km) ! Was used for towing a boat - mostly short trips to the local ramp...
FollowUp 1 of 2
