LPG and Valve Saver Fluid
Submitted: Wednesday, Jun 27, 2007 at 16:26
ThreadID: 47166 Views:5541 Replies:5 FollowUps:2
Hi Folks
Can anyone tell me how much valve saver fluid l should be going through on a 4.Lt DA Maverick (or GQ Patrol), I was hoping someone could help me out as there is no LPG Specialist in Broome as far as I can find, I was told approximately 50ml per tank (100Lt) but I appear to be going through nearly 300 per tank.
Thanks in Advance for any input.
Matt
Reply By: bass_straitener - Wednesday, Jun 27, 2007 at 17:29
Hi Matt,
The recommended dosage using the Valve Saver kit is one drop per 12 seconds. This is according to the manufacturer.
Regards, Bruce
AnswerID: 249483
Follow Up By: lc_120man - Wednesday, Jun 27, 2007 at 17:48
The recommended dosage is 12 drops per minute, which works out
to be about 1 drop per 5 seconds....
FollowupID: 510461
Reply By: RupertDog - Wednesday, Jun 27, 2007 at 17:33
Godlike Chef
I have a 99 Prado, and was advised about 50ml per tank. There shoudl be an adjustment on top of the Vale Saver Bottle, next to the window thru which the fluid drips (don't think that is the technical name?). A small easily adjust thumbscrew.
With the engine idling, you can adjust the flow of the fluid. Mines works out at about 1 drip per 2 secs. Worth playing with until you get it close.
I managed to knock mine last week end, and used half the bottle. Knew something was amiss as i had a great cloud of smoke everytime i started up. Slight adjustment an all is well.
Good luck
Rupert Dog
AnswerID: 249485
Reply By: lc_120man - Wednesday, Jun 27, 2007 at 17:54
The instructions are here:
Site Link
AnswerID: 249491
Follow Up By: Godlike Chef - Wednesday, Jun 27, 2007 at 18:49
Thanks guys for all your advice. Makes it easier knowing how many drips per second than ml per tank! Thanks for the site link as well lc_120man I never thought of that! DOH!
FollowupID: 510484
Reply By: Ray Bates - Wednesday, Jun 27, 2007 at 19:09
I set mine at one drop every five seconds but I use top quality two stroke oil
AnswerID: 249513
Reply By: Member - DOZER- Thursday, Jun 28, 2007 at 09:34
Diesel is also a good hydrocarbon to use, but re-adjustment of drip rate is necessary due to thinner consistancy...these are not the b all and end all but do help the lpg runner motor..for instance, there is more mnifold vacuum at idle than at coast, where you need the oil most....so you are better off using cheaper oil and more of it :)
AnswerID: 249620
