A question for the TURBO guru's
Submitted: Wednesday, Jun 27, 2007 at 18:15
ThreadID: 47171 Views:1907 Replies:2 FollowUps:1
On the GU3 4.2 iTD does the turbo have a fixed wastegate or an automatic one that opens and closes with pressure/vacuum?
I assume it is an auto one as i can see a diaphram housing, and an arm to where i would picture the wastegate to be, only thing is a can't move it, nor do i see it move when i rev the engine.
Is this normal, or should i be able to move it and see it move?
Thanks folk in advance
Wayne-o
Reply By: burnsy - Wednesday, Jun 27, 2007 at 18:33
Don't know for sure about your Nissan but I assume that the waste gate is operated by boost pressure, hense the diaphram that you can see. What I do know is that on after market turbos it is very difficult to move the waste gate lever.try putting a shifter on the lever and see.I think you would soon know if the waste gate was stuck
regards
Mike
AnswerID: 249504
Reply By: CMB - Wednesday, Jun 27, 2007 at 19:24
Wayne,
The arm you describe does join to the waste gate. If this were not connected to the diaphragm as you describe, you would be able to move it with your little finger. The diaphragm is normally hokked via a tube to the inlet system. The more pressure, the more it pushes on the wastgate until it opens (at the pressure set by the factory - 9 psi on my 1999 rig). You can shorten this rod (on some models) to increase the turbo pressure (up to about 15 psi which is where the safety dumps blows off and drops the pressure back to about 8 or 9 psi). You will have to be very strong to be able to move the rod if it is still connected to the diaphragm, especially if it is still in place as it is difficult to grip.
If you have a wire coming off the diaphragm, you have an electronically controlled wastegate.
Oh yeh, reving your engine to the point of destruction in your drive way will not produce much turbo pressure so you won't see the rod move. Put it on a dyno under load and then take a look.
The newest turbo fitted these days uses a variable vane turbo where the turbo housing is in "2 halves" and each half is rotated to give varying degrees of boost throughout the rev range (depending on power required ie throttle position Vs engine revs). Old technology but fits the bill to meet tier III emission controls.
Chris.
AnswerID: 249524
Follow Up By: Wayne-o (Pilbara WA) - Wednesday, Jun 27, 2007 at 20:19
hey
thanks very much, i think i have my head around it now. It is definately boosting, i can both feel and hear it.
Much appreciated
Wayne-o
FollowupID: 510525
