AnswerID: 19178 Submitted: Monday, May 05, 2003 at 17:33
crowie
replied:
Thanks for the responses. Will I'm sure your probably rightl and that preconditions for lock up are changed electronically in low range. I little bit more experimenting is needed. Perhaps Nissan has thought of everything!!! Its also right that the vehicle would stall like a manual if the TC was not unlocked at very low speed, though in the conditions I was thinking of, low range steep downhillers i guess the driver would just have to remember to switch the lock up off (like depressing the clutch) or change up a gear if and when engine braking overcame the slope and the vehicle started to stal.
I have read that most TC's unlock when the accelerator is released. For example going down hill in overdrive, foot off accelerator and so a certain amount of engine braking is lost. It would be nice in this situation to be able to keep the transmission locked and get a bit more engine braking in these sort of situations without the need to resort to brakes..
Apparently GM diesels with Allison overdrive autos have two modes: normal and tow/load. In normal mode lockup occurs in 4th and 5th but presumably in tow-load in lower gears and speeds.
I will experiment to asertain when lockup is occuring in different modes and try and get some techinical guff from Nissan or from someone with the official GUII manual.
Thanks again.
Reply 3 of 3
