battery which one?
Submitted: Wednesday, Jun 27, 2007 at 21:17
fujimiester
Can anyone recommend a good battery for cranking and a second one for the fridge/lights etc. I am installing a dual system. In
Melbourne pls preferably north/east subs. I am still using the original in the playdoe after 5 years.
fj
Reply By: Derek from Affordable Batteries & Radiators - Wednesday, Jun 27, 2007 at 21:21
Hi fuji
What exactly do you drive and what size is the battery trays ?
Derek.
249565
Reply By: Sand Man (SA) - Thursday, Jun 28, 2007 at 02:52
For a starting battery, the Exide Extreme is hard to beat for value, performance and availability.
For an Auxiliary, one of the AGM style deep cycle batteries will give the best performance. Just keep in mind, size (footprint) may be an issue if you are installing it in the Engine bay.
249592
Reply By: Member - MrBitchi (QLD) - Thursday, Jun 28, 2007 at 07:59
I second the motion for an Exide Extreme :-))
Could also use a second one for your auxiliary. Value for money wise, won't really matter if it only lasts 4 years instead of five....
Personally I have an Exide as the starter and a Trojan deep cycle as the auxiliary, but only cause I got it at the right price.
249606
Reply By: meandet - Thursday, Jun 28, 2007 at 08:41
Hi fujimiester
I use identical Exide Extremes in the vehicle and the
camp trailer (if the vehicle battery fails, I can pinch the one out of the
camp trailer to keep rolling) The second battery in the vehicle is an Optima yellow top and it has been a terrific battery for years but they are expensive. One of the main things I like about it is its ability to take charge quickly. Apparently you can charge one in 35 minutes if you can provide enough juice, some deep cycle batteries take a lot longer. We then use 2 x 40 watt solar panels to keep it all charged during long stops.
249612
Follow Up By: Gronk - Thursday, Jun 28, 2007 at 12:40
Charge a battery in 35mins.......I'd like to see that !! Ahh, a trick question.....maybe it was already 98% charged !!
510647
Follow Up By: meandet - Saturday, Jun 30, 2007 at 07:40
Optima info not
mine. From experience, I know that it charges fully without too many
miles of driving.
511074
Follow Up By: Mainey (WA) - Sunday, Jul 01, 2007 at 18:38
Yes, Optima is AGM technology so will recharge quickly, those with-out AGM often don't understand and looks like they may not believe the benefits available with AGM batteries either lol
511330
Reply By: Ronnie - Thursday, Jun 28, 2007 at 18:17
The best one I have found for cranking the Nissan over is Supercharge Gold(720cca from memory ) runs rings around Exide Extreme and standard battery .
Regards Ronnie
249692
Reply By: Mainey (WA) - Sunday, Jul 01, 2007 at 18:42
fj, just a question, who will you believe when you get two or three different replies that appear to make sence to the relevant posters ??
Have you asked a "Specialist Battery Supplier" the same two questions?
What brand of battery do you presently use ??
250185
