O/T flow coat marine paint
Submitted: Thursday, Jun 28, 2007 at 20:03
ThreadID: 47211 Views:4893 Replies:1 FollowUps:6
Hi guys just wondering if you can use thinners to water down marine flow coat to make it go further.
Thanks ross
Reply By: Member - Uncle (NSW) - Thursday, Jun 28, 2007 at 20:13
Hi Ross, if its the marine grade , with a "resin" smell to it, we used to use a small amount of acetone to thin it down, but not too much as it will go too watery.Unc.
AnswerID: 249716
Follow Up By: Member - Ross H (QLD) - Thursday, Jun 28, 2007 at 20:17
Yes Uncle its the marine grade and bloody thick. How much is not to much acetone I have 1kg of flow coat.
thanks ross
FollowupID: 510737
Follow Up By: Member - Uncle (NSW) - Thursday, Jun 28, 2007 at 20:22
I'd use a cup of acetone to 1 litre of flow coat, also add some straight resin as well, just keep stirring it till it looks as though its easy enough to brush on, if thats what your doing with it. We used the flowcoat to cover the inside of canoes when I was building them comercially years ago. Dont forget the Catalyst (hardener).
FollowupID: 510741
Follow Up By: Member - Ross H (QLD) - Thursday, Jun 28, 2007 at 20:28
Thanks uncle
Will go do it now.
Regards ross
FollowupID: 510743
Follow Up By: Member - Uncle (NSW) - Thursday, Jun 28, 2007 at 20:33
Ross if it needs thinning more tend to use resin to thin it out rather than too much acetone.
FollowupID: 510744
Follow Up By: Member - Ross H (QLD) - Thursday, Jun 28, 2007 at 21:51
Thanks uncle worked a treat and job is all done just has to dry now. Would of had enough yesterday if I didn't put so much catalyst in as it went off about 3min to soon. Put a bit extra in as it was only about 10 deg last night but just too much and couldn't catch it in time. Oh well all done now and camper will stay dry for our trip down to crow eater country haha. Thank again.
regards ross
FollowupID: 510762
Follow Up By: Member - Uncle (NSW) - Thursday, Jun 28, 2007 at 22:32
Good to hear Ross, have fun and drive safe.
FollowupID: 510777
