Leaking Injector Pump
Submitted: Sunday, May 04, 2003 at 23:12
Member - Wayne
G'day all
Have noticed this afternoon that the injector pump on my TD42 has developed a small leak. Drips appear from the rear of the pump just underneath where the injector lines come out of the pump.
Is this a job that requires a service of the pump, or is there somewhere I should look for the leak? I've tightened every nut, bolt and screw I can see but still leaks at the same rate.
Any ideas of price? Anyone in the
Pilbara (
Karratha) know of the "best" place to go for this sort of work?
Wayne
Reply By: bruce.h - Monday, May 05, 2003 at 14:03
wayne
had a similar problem with my gq the seals perished due to the low sulpher diesel had
mine fixed by armadale 4wd service centre in perthcant remember as to costings but dont think it was hugh cost any diesel machanic shuold be capable of replacing the gaskets of the pump
Regards bruce
19170
Follow Up By: Dozer - Monday, May 05, 2003 at 20:28
Hope you guys are pressing the fuel company for a refund of what it costs to fix.
12052
Follow Up By: bruce.h - Monday, May 05, 2003 at 23:24
Dozer
im no fan of petrol co but in this case it the government to blameas its now part of law for making low sulpha diesel due to the keoto proticol
12064
Reply By: David N. - Tuesday, May 06, 2003 at 13:44
BP paid to fix
mine a couple of years ago- but I don't think they still do that.
Low sulphur diesel is actually better for you AND your TD42! Low sulphur means you can extend oil change intervals and your motor will probably last longer. (The excess Sulphur reacts with
water vapour and forms sulphuric acid = internal corrosion of your donk = bad news)
19255
Reply By: tex1972 - Saturday, May 10, 2003 at 20:31
brace yourself folks, since the changes to the formulation of diesel leaking pump seals is commonplace.thanks to the government for this one maybe we can claim it as a tax deduction.
19627
