AnswerID: 250629 Submitted: Tuesday, Jul 03, 2007 at 23:05
Dallas from Team Green Autogas
replied:
G'day Snowy,
I've found that spark plugs don't seem to make alot of difference at all. Normally faulty / worn plugs would cause it to backfire when on gas. Might be worth checking to see whether they replaced the air cleaner or at least dusted it out. Basically, if they've changed the air cleaner & now the engine is able to pull more air easier, it reduces the vacuum / draw on the lpg converter & it doesn't deliver as much gas. You'll starve of gas under load, running lean whenever you put your foot down & possibly backfiring even.
If it's got a manual flow adjuster in the vapour hose from the converter to the mixer, open it up 1 turn at a time, counting the number of turns & see if it makes it any better. If it doesn't come good then go back to where you started & go in 1 turn at a time & see if you can find the sweet spot.
If it's got a stepper motor then it'd be worth getting it into someone with a scan tool for that gas system & they should be able to adjust the program.
Dallas Green
 | Team Green Autogas Member: Lapsed Membership |
Reply 7 of 8
