Which oil ???
Submitted: Monday, Jul 02, 2007 at 22:18
TrishP
Hi guys
Can any of you help me. I have a Rodeo 2.8L Turbo and recently had the engine rebuilt. new
bore, new rings, valve guides done etc. It's done abt 20,000 ks since the rebuild and I am getting excessive pressure in the crank case resulting in oil being blown out the breather tube. As far as I am aware the rings were put in correctly. Has anyone else had this problem, could it be the oil I am using i.e. Vanellus Global which it has had since rebuild. Your comments would be greatly appreciated. Ta
Reply By: mike w (WA) - Monday, Jul 02, 2007 at 23:23
TrishP,
any 10w 40 or 15w 40 Diesel engine oil will be fine. I noticed that Vanellus Global is a 10w 40, which shouldnt make to much difference, just not as good in colder temperatures on start up. Otherwise, I could not see it as cause to be blown out of the breather tube.
First thing to check may be the oil level. Check it isnt overfull, as the excess oil would have to go somewhere, and a breather tube sounds like a likely candidate. I know that the manual says to fit 6.5L, but ive never fitted that much in. There always seems to a bit of residual left in the engine.
Otherwise, Im out of ideas. Good luck
Mike
250415
Follow Up By: TrishP - Tuesday, Jul 03, 2007 at 14:01
Thanks Mike, the car was not overfilled. I believe someone said someone (don't know who) that synthetic oil does not allow rings to seal properly on new sleeves and I am wondering if anyone has heard anything like this. Had new pistons, sleeves, rings etc. when engine was rebuilt. Haven't got original manual so don't know what they originally recommended. Had it all done up for desert crossing in August - now using a bottle to catch excess oil through the breather tube. Don't really want to go to the trouble of pulling it all apart to check the rings again as the mechanic was very thorough putting it back together for me. Runs
well, just this blow by problem.
Puzzled - Trish
511658
Reply By: Member - Bucky (VIC) - Tuesday, Jul 03, 2007 at 07:42
First thing I would do is get it compression tested
I'm no expert but from what I have been told is that if oil is being blown back out anywhere, then you have a problem.
If you have a positive crackcase ventilation system, ( not too sure ) then check it to make sure the valve is not stuck.
Are you using the recomended class and viscosity oil ? as per the drivers manual !
Apart from that I cannot offer any advice, except to take it back to the people where you had it done, and if you did it yourself then you may have got something wrong somewhere.
By chance was the original pistons used, and maybe one has a hole in it.
Did you check the ring gaps ?
I'm not too sure what they are supposed to be, but just a little over could be detremental
Did you get just one of the rings in the wrong spot ?
Or did one ring crack during installation ?
Were the rings correctly rotated, ? ie one piston may have ring gaps down 1 side, there is a correct position for them.
I wish you luck and please let me know the prognosis !
Bucky
250425
Follow Up By: TrishP - Tuesday, Jul 03, 2007 at 14:13
Don't have a valve in this motor. Can't find driver's manual. Had the whole engine properly done up, valve springs, guides, with new cylinder liners (Chrome), new pistons, new rings, timing has been checked, fuel injection pump, the works. When it came to fitting the rings, these were carefully checked to ensure right way up and correctly rotated - i.e. no gaps right underneath oneanother. (done by a mechanic).
She now runs like a dream but I just have this problem of blowby with the oil. Someone somewhere mentioned that synthetic oil does not allow rings to seal properly against chrome sleeves and I was wondering or at least now hoping this is my problem. Have you heard about this.
Cheers Trish
511661
Follow Up By: Member - Bucky (VIC) - Wednesday, Jul 04, 2007 at 05:39
Actually now that you mention the synthetic oil thing, I recon that might be your best bet,,,, the rings have to wear ( bed ) in .
Good luck
Bucky
511787
Reply By: brushmarx - Tuesday, Jul 03, 2007 at 10:55
There is quite a bit of info on all things Rodeo (Isuzu) on www.clubisuzu.com
You could do worse than tour through thier website.
Ian
250463
Follow Up By: TrishP - Tuesday, Jul 03, 2007 at 14:17
Hi Ian
Thanks for telling me about this site - will certainly check it out.
Regards Trish
511662
Reply By: Chris & Debbie - Wednesday, Jul 04, 2007 at 09:40
Although I prefer not to use a synthetic oil for the run in period and only use a cheap oil it should not matter as a lot of car manufactures use it from the factory, but in saying that if you baby'd the engine or let it idle too much the
bore could have glazed. There are products available for deglazing if this is the problem.
You say you have cylinder liners with chrome bores are you sure that the rings were not chrome plated as
well? chrome rings can never be fitted to a chrome
bore.
Chris
250670
Follow Up By: TrishP - Wednesday, Jul 04, 2007 at 10:41
Hi Chris, Thanks for your remarks. The engine reconditioners fitted chrome sleeves in the bores and they supplied the new rings, pistons etc. so one would think they were compatible. As stated, I have been using Vanellus oil and I am not sure if this is synthetic or not. I need to know which oil I can get that is real oil, not synthetic to try and see if rings will bed in properly - hopefully the problem. You mention products available for deglazing, can you name any? This engine is not baby'd, headed off to Fraser Island during the first thousand ks of it being reconditioned.
Trish
511822
Follow Up By: Chris & Debbie - Wednesday, Jul 04, 2007 at 12:00
Trish
There is a de-glazing product made by CEM (Cost Effective Maintenance), I know nothing about it only what i have read on this
forum and on their web site, may be worth giving them a call, Caterpillar also make/made a fuel additive for deglazing.
I doubt glazing would be your problem though I would say it is more to do with an assembly problem such as a broken compression ring. The best thing to do would be to get onto the reconditioners and get them to troubleshoot the problem.
Chris
511833
Reply By: G.T. - Friday, Jul 06, 2007 at 16:53
You mention that your cyl liners are chrome. Is this the overall type of metal of the liner or does the liner have a chrome
bore? If the latter ,did the pistons come with chrome plated rings especially the top rings? If so you have a problem as chrome rings cannot be run in a chrome
bore. Hopefully this is not the case in your instance, but chrome rings will not bed in a chrome
bore. Just a thought . Regards G.T.
251084
