FollowupID: 511839 Submitted:
Wednesday, Jul 04, 2007 at 13:49
Wizard1 posted:
ddr,
I'm not exactly sure if your on the same scipt of music.
My advice was regarding the problems a lot of owners have had with the adherance to the ADR by positioning the coupling on the van at the bottom of the frame (so it doesn't exceed the 420mm height off the ground), not the top which was the traditional setup and still is for most "road" vans with the smaller box frame.
If you check the sites I listed you will note a plaethora of problems trying to use a WDH with the lowered coupling on the frame. In fact several Hayman Reese hitches couldn't lower the ball anymore. I know several owners that have had to fit spacers to raise the coupling higher on the frame baseplate.
Your advice about the Hyland ball, etc is a little strange. I have a Hyland and use my normal Hayman Reese WDH. I see no reason to swap over, all you need to do is remove the bars to facilitate added articulation. Darren Hyland didn't seem to think it was an issue. Also if you have one of the later hitches then a normal 50mm ball is fine, you don't need a special Hyland one, unless you tow over 2000 kg.
My advice was to help a prospective owner ahve to deal with fix-ups for a problem after they gate the van rather than be aware of them up front and perhaps avoid dramas later.
