diamond cutting wheels
Submitted: Thursday, Jul 05, 2007 at 16:53
earwig65
Gday fella's, just wondering whether any of yez have had any experiences with small diamond cut off
wheels, the type i refer to are the ones commonly seen with Dremel machines or the like, i was interested to know if these discs, once fitted to a variable speed drill, will cut the head off of a high tensile bolt, much like the ones you would have in your engine holding the cylinder head in.
Talk to yez, soon. thanks. Earwig.
Reply By: fisho64 - Thursday, Jul 05, 2007 at 17:11
I dont know that you would use a diamond wheel for that?
Is that what you actually want to do or are you just drawing an analogy?
I think a variable speed drill would be way to slow for a Dremel tool bit of any sort?
tell us what you are actually attempting to do and maybe someone can assist?
250920
Follow Up By: earwig65 - Thursday, Jul 05, 2007 at 17:17
Yeah,, i'm trying to remove the head on the Pajero, & without boring you with the sad tale, i am left with this final option,,,,,to cut off the head of the last remaining, deformed & mutilated bolt at
the neck,,because i cant drill it off,,,,i wish i could.
512063
Reply By: Member - Kiwi Kia - Thursday, Jul 05, 2007 at 17:53
Diamond blades come in many different types. For optimum use they must be run with a coolant and at the correct speed and preferably with a constant slow advance. Depends on the material but you could destroy the blade very quickly. A blade made for use with ceramics would last no time at all if used on hardened steel. For the use that you describe you want a very thin (yes they do make them) carborundom disc but you must make sure you do not get any of the abrasive particles into any of the inner workings !
I would only try cutting the bolt head off as a last resort. Have you tried welding another bolt/nut onto the top of damaged one ?
250929
Follow Up By: earwig65 - Thursday, Jul 05, 2007 at 19:26
Yep, tried that, we welded the allen key-socket into the bolt, as the bolts hexagonal hole was getting rounded out, the allen key socket bleep tered & yes, it was a good one,,(Snap-on) so part of the allen key is now welded & embedded into the bolts head, which is quite a bit harder than the bolt evidently,,,,,,,,running out of ideas & patience!
512080
Follow Up By: Member - Kiwi Kia - Thursday, Jul 05, 2007 at 20:31
Excuse me for asking but...did the welder know what he was doing ? Simply using the old archimedes and melting the two together you may have cyrstalised the metal and made it brittle. You will need to heat them first or do it a little at a time. Hardened Allen keys are brittle, you may have to just weld a larger steel bolt or nut onto the head bolt.
512088
Follow Up By: earwig65 - Thursday, Jul 05, 2007 at 20:47
Nah, clearly he didnt,, tho i didnt do the welding,,i guess i shudve thunk of it before i let him weld it on,,still,,i hope
the nut will prove to be a successful alternative,, wish me luck & thanks for your suggestions.
512093
Reply By: Hairy - Thursday, Jul 05, 2007 at 17:57
Gday,
Dont do it! Diamond blades are meant for masonary, not steel.
Just use a normal metal cutting blade, They now come in 1mm thick blades and are really handy.
250930
Follow Up By: earwig65 - Thursday, Jul 05, 2007 at 19:32
Thanks Hairy, but i'd need one 40mm in diameter given the area i need to use it in, its snuggly being hugged by 2 shoulders of aluminium that are part of the cylinder head,, if you know they make 'em that size, i'll take a dozen.
512082
Follow Up By: Member - Mike DID - Thursday, Jul 05, 2007 at 21:36
I use Dremel 25mm cutoff discs all the time to cut steel an extremely useful tool.
You may find a 12 volt Dremel-type tool will be cheaper than a Dremel.
512106
Follow Up By: earwig65 - Thursday, Jul 05, 2007 at 23:08
thanks Mike,, have you used them on high tensile before? these bolts are 10mm thick, you like my chances or what??
512120
Follow Up By: Member - Mike DID - Friday, Jul 06, 2007 at 08:25
Yes, that's what I use on Stainless Steel bolts.
It's slow and the disc won't last long - but it works for the occasional cut.
512159
Follow Up By: earwig65 - Saturday, Jul 07, 2007 at 10:47
excellent, thanks Mike,,i've ordered one!!!! Cheers, Earwig.
512328
Reply By: Eric Experience - Thursday, Jul 05, 2007 at 21:54
Earwig.
What I would do in this situation is find a piece of steel tube with a
bore that is the same size as the screw head, cut of a piece about 30 mm long and then drive it over the screw head. then get a die grinder with a stone the same size as the
bore and grind down on the broken allen key until it is gone, you may have to replace the tube during the process if it gets ground away. When the key is gone you can either drill out the screw or keep grinding. Eric.
250976
Follow Up By: Member No 1- Friday, Jul 06, 2007 at 07:25
ditto that
512139
Reply By: russ36 - Friday, Jul 06, 2007 at 06:11
the abovementioned 1mm mini discs for cutting steel are only about 100 mm diam. perhaps you could just use them elsewhere till they wear down to the 40 mm diam you need
251009
