FollowupID: 12076 Submitted:
Tuesday, May 06, 2003 at 12:38
Old Jack posted:
yes the compression engine will happily run on any fuel that you can get into the combustion chamber, rudolf diesel created the engine to run of any cheaply available fuel, there are large "diesel" engines that run of powerded coal! used in ships, etc.
another writer here talked about generator sets running on "gas" this is usually natural gas where available. motor runs usually gas only in this case.
the injection system that runs oil/gas combination is pretty neat, really suited for hight pressure common rail injection, there will soon be a new breed of "petrol" engines that uses compression ignition(diesel), just to confuse people, ie it has no sparkplugs & runs on petrol!
just a cleaner fuel to handle thats all.
