duplex button
Submitted: Tuesday, May 06, 2003 at 09:17
wal
I have recently purchased a uniden 011, although I have a basic idea of the duplex mode and repeaters, I am unable to tell when it is in duplex mode, I push the button but no light shows what mode it's in. Am I doing something wrong? should a light lock on to tell me it's in duplex? any help appreciated.
Regards Wal
got to get it right for the Cape in July
Reply By: Gerry - Tuesday, May 06, 2003 at 09:51
Wal, I don't know the model off-hand but it should show "DUP" or similar on the display. However, it only works on channels 1 to 8 so nothing will happen on higher channels.
19234
Reply By: ROBERT - Tuesday, May 06, 2003 at 10:01
YOU CAN ALSO TELL IF YOUR GETTING THE REPEATER NY HOLDING IN THE TALK BUTTEN FOR A SECOND WHEN YOU LET GO SHOLD BE ABOUT A SECOND OF SILENCE BEFORE YOU HEAR THE STATIC
19238
Reply By: Time - Tuesday, May 06, 2003 at 13:27
Wal
On channels 1 - 8 if you push the duplex button you should see the "Dup" light up, or go out, on the LED display. Obviously if it is lit up Duplex is on, if not it is off!
Buggerlux
19252
Follow Up By: Phil - Tuesday, May 06, 2003 at 15:04
Sorry for butting in but what does "duplex" mean and what does it do?
12090
Follow Up By: wal - Wednesday, May 07, 2003 at 10:10
Thanks for the info fellas I think the led on the duplex button must be stuffed.
12145
Reply By: Maciej - Tuesday, May 06, 2003 at 22:42
duplex is two way comunication
19315
Reply By: Member - Russell - Wednesday, May 07, 2003 at 21:17
I too am trying to get duplex straight in my head. My understanding is that in duplex mode, your radio will receive on (say) channel 1 and transmit 30 channels higher on 31. Any repeater station in range will receive your signal on 31 and transmit on 1. The duplex function is available for channels 1-8. Some info available on
http://www.alphalink.com.au/~parkerp/cb.htm
with lists of repeater stations etc.
Wal - can't help any more than the others, your radio may have a problem. GME rules in my book.....
Russell S.Russell S
Prado RV6
19403
Follow Up By: Member - Nigel - Saturday, May 10, 2003 at 18:33
Yep you've got duplex figured correctly.
And yep GME rules.
12424
Reply By: Niko - Saturday, May 24, 2003 at 06:05
The channels 1-8 are the repeater channels and thats where duplex works.
20908
