Tuesday, Jul 10, 2007 at 10:59
Emo, in your original post you state: "I'm thinking of getting a solar panel to run my fridge whilst camped for LONGER periods"
Under those conditions I would ONLY recommend an AGM battery, NOT a wet cell battery.
Reason being an AGM battery will recharge much faster than any wet cell battery and that is the secret, as you have a limited number of 'sunhours' per day you must take full advantage of them and get the most charge into the battery as is possible in the given time, a wet cell battery will recharge less in the same time period and if you get 3 sunless less days you will run out of
battery power.
You should buy the most EFFICIENT solar panel you can afford that fits in the space allocated to store it, as it's a 'move-a-round' solar system and will not be attached to the roof for transport & use. By getting the most efficient you then get the smallest physical size required to to the job needed. Most quality and also efficient panels have the module efficiency stated in their specifications, generally if the efficiency rating isn't mentioned you can only believe it's because it's not rated and in the top of the % numbers and therefore it's not worth the money. If you have a definite choice of panel and can't find it's rating I will endeavour to get it for you.
The solar regulator MUST be capable of replicating the benefits of a 3 stage battery charger, with the power coming from the solar panel instead of a 240v plug, not a single charge regulator.
A regulator with a LCD screen is useful as it allows you to set the panel up to it's most productive angle, as you can see the actual number of Amps going into the battery and also produced by the panel, there is no real second choice in this matter unless you have a panel fixed to the van roof etc.
512746
