AnswerID: 1259 Submitted: Monday, Oct 22, 2001 at 00:00
Tony
replied:
Hi Greg. I added a turbo to my 1HZ. Make sure the fitters weld/braze or silver solder the fitting for the 'oil return line to the sump' to the sump. Some just punch a hole and thread the fitting. Mine fell off at
Cape York. The dealer paid for the repairs (thankfully) and showed me the manufacturers fitting instructions where the punch and thread method is the recommended method. They (the dealer) have since changed the way they fit them after several failures. Also would have preferred the sump to be removed *before* making a hole for the return line. Make sure the fitter has the equipment and experience to adjust the fuel pump. You need to bump the fuel delivery up a bit with a turbo. No point in having extra air if there's not enough fuel to take advantage of it. Check if boost and/or ETG guages are an option. Boost gauges are cheap to add later but I'm having a hard time finding an ETG at a realistic price in OZ. Mine is water cooled - some aren't. Fit a turbo timer, but be warned, a new law in NSW makes it an offence to leave your vehicle running if your not in it. Locked or not makes no difference. As a matter of fact, in NSW it is now an offence to not lock your vehicle if you leave it. Adding a intercooler adds heaps extra power but they nearly double the price, not sure if it is worth the extra. I haven't tried different brands of turbo, this one is my first. Tell your insurance company but expect the premiums to increase.Fuel ecconomy may improve or could get worse - depends on how you drive. Make sure you change your oil evey 5k. The turbo is harder on oils. I change my filter each time I change my oil. On the 80 series there is a dust bowl on the bottom of the air cleaner box. This can rub against the inlet tubing from the turbo, mine does. I don't know how to correct this as yet so I keep an eye on it and replace it if it looks like wearing through. I think the turbo needs to be rotated a degree or two but I dont know if this is possible. Thats about all I can think of.
Reply 1 of 3
