Compressor position
Submitted: Wednesday, May 07, 2003 at 21:16
ThreadID: 4787 Views:2734 Replies:9 FollowUps:11
I'm interested in peoples opinion as to where to permanently mount an air compressor, two schools of thought, under the bonnet or in my case under the drivers seat. Pros and cons for both, air cooling issue under the seat and water and dust contamination under the bonnet, this is going in my "Bush Hack" Rangie so it will be spending the majority of it's time in the scrub.Keep the shiny side up
Reply By: Member - Bob - Wednesday, May 07, 2003 at 21:47
Martyn, you're obviously a better bush cook than me, because under the drivers seat is the last place I'd be looking for clean air. I have ARB's mounted under the bonnet of the TD5 and LX470 - no problems with dust or water so far. On the last trip we also had an ARB in a box. It worked well but the box was an unecessary extra occupying valuable invehicle space.
AnswerID: 19407
Follow Up By: Member - Bob - Wednesday, May 07, 2003 at 21:50
I also meant to say that the closer the compressor to the baTTERY, THE LESS THE VOLTAGE DROP, and the easier the wiring.
FollowupID: 12200
Follow Up By: Member - Martyn- Wednesday, May 07, 2003 at 22:26
Bob,
I'd also heard about the voltage drop issue all I can say about that is I've had the compressor mounted under the passengers seat in my GQ and never had a problem with voltage drop, not that I would be able to notice the voltage drop anyway, how would I spot it, would the compressor go slower? I just did a beach run recently and when i got back there was sand under the engine bay, not what I viewed as a good place to store an air compressor. Keep the shiny side up
FollowupID: 12202
Follow Up By: Member - Wherethefugawi - Thursday, May 08, 2003 at 07:38
Bob, I notice you mentioned you hace a v8 cruiser...if you dont mind me asking, what is fuel economy like and how do you find it over the six versus diesel
RichardCheers
FollowupID: 12205
Follow Up By: Kev - (Cairns,QLD) - Thursday, May 08, 2003 at 17:10
There shouldnt be a problem with voltage drop no mater where you put it.
To over come voltage drop use larger diameter cables !
FollowupID: 12235
Follow Up By: Member - Bob - Thursday, May 08, 2003 at 21:53
Wherethefugawi, I think it does about 20L/100km around town and about 16 on the hwy. On the recent trip (of about 6000km) my mates took it upon themselves to fuel the V8 and I fuelled the TD5. Despite its larger capacity they were always filling at every stop whereas the TD5 was regularly returning over 900 witout the trailer and 700 while towing. Sorry I can't be more specific. Don't get a petrol 100 series or LX470 if you want good fuel economy - its pretty expensive to run.
FollowupID: 12250
Reply By: nugget - Wednesday, May 07, 2003 at 23:28
Martyn,
I wouldn't mount a compressor under the bonnet mainly because of all that heat. If a compressor starts when it is allready sitting in an engine bay with an ambient temperature of atleast 60 degrees or more, its just going to reach its thermal cutout switch that bit sooner. Its like going offroad in a Toyota; your allready that far behind!
AnswerID: 19410
Follow Up By: Kev - (Cairns,QLD) - Thursday, May 08, 2003 at 17:12
Jealousy is a curse !
FollowupID: 12236
Follow Up By: Member - Bob - Thursday, May 08, 2003 at 21:57
Heat hasn't been a problem in Pajero, LX470 or TD5. Even in hot desert conditions. Nor has sand dust or water.
FollowupID: 12251
Reply By: Truckster (Vic) - Thursday, May 08, 2003 at 00:04
MInes under the drivers seat, as the last 2134 threads on it.
another option is under rear seats, or INSIDE the rear 1/4 panel.
AnswerID: 19412
Reply By: brian - Thursday, May 08, 2003 at 07:50
Mine is bolted to cargo barrierbehind rear seat,no dust,water,is cool and the hose can reach the camper van and all tyres on the truck.if you tow anything dont put in engine bay or you wont reach the van.happy travelling
AnswerID: 19415
Follow Up By: Member - Martyn- Thursday, May 08, 2003 at 09:01
I do, thanks for that school of thought I must admit I had't realised that with my Nissan where I have the air point on the bullbar, ummmmmmm, thanks for that Brian.Keep the shiny side up
FollowupID: 12208
Reply By: crfan - Thursday, May 08, 2003 at 10:19
I have mine mounted under the bonnet opposite side to the exhaust
find it out of the way no probs with dust (comp has replaceable air filters)and makes it easyer to clean inside my cruiser.
I end up with enough stuff inside my car with out bolting stuff in.
But probaly is better for the comp in side the car.
AnswerID: 19420
Reply By: Outnabout David (SA) - Thursday, May 08, 2003 at 13:25
Martyn,
Put it wherever you don't need the space. I find under the seat a good place to store lots of things that I need in a hurry so I wouldn't put it there. Under the bonnet is fine if you have the space 'cos there is not much else to put under there. The only problem is dust in the fittings so just put a bag over them if it worries you that mauch. I don't bother and I have had mine under there without a cover for several years and no problems. If you want to get really fancy secret mount it behind the trims in the back but that is a lot of work but looks neat.We have so little time to enjoy our land
AnswerID: 19430
Follow Up By: Gerry - Thursday, May 08, 2003 at 14:00
Like a lot of the previous responses, I also have it under the passenger seat of my GQ with no prob's. This location also makes it easy to add an extra air tank directly underneath next to the chassis rail with just a short pipe through the floor (sealed of course) between the two.
FollowupID: 12226
Reply By: wal - Thursday, May 08, 2003 at 20:01
Buggeded if I know my super cheap model comes with it's own bag and will put 20psi into my patrol tyres in 3 mins flat, I hope i'm never in that big a hurry that I cant reach into the back of the wagon and get the compressor bag out.
AnswerID: 19448
Follow Up By: Member - Martyn- Thursday, May 08, 2003 at 21:48
Wal,
You are right, I suppose I just like the easy way, I've been stuck in rain when yes there has been a bit of a rush, and also when I've rolled a tyre the convenience of being able to plug the air line on and flick a switch has been nice, it all comes down to personal choice.
FollowupID: 12249
Reply By: duncs - Thursday, May 08, 2003 at 22:36
Mines under the bonnet on a GU 4.2.Turbo & I'm moving it. I recently stopped to help a guy at the side of the road after running at highway speeds for a while and the thermal cut out was hard at work. My last car GQ 4.2 with turbo had the same model compressor under the front passenger seat and never had a problem.
As has previously been mentioned, it's also easier to reach the trailer tyres from further back in the car.
No there were no problems with dirt, kids feet or wives handbags and there was the added advantage of fart jokes for the unsuspecting mate.
Duncs
AnswerID: 19457
Reply By: ken - Friday, May 09, 2003 at 00:29
I'm surprised no-one has suggested you chuck it away and mount up an old a/c compressor. Supposed to be mega fast, cheap as dirt simple to set up, etc. But that's probably a whole new thread........... Me, I've got the Blue Tongue under the bonnet - never a problem.
AnswerID: 19465
Follow Up By: Phil G - Friday, May 09, 2003 at 08:57
Likewise - Blue Tongue under the bonnet - fan cooled. I use a rubber grommet to stop dirt getting into the air connector.
Had it in the back before that - good location as long as you use substantial wires (say 8gauge) going thru to the back. These pumps draw the best part of 20 amps.
Best way to see what a difference voltage makes is to run the pump under load on one of your tyres, then start the vehicle up and note the difference an extra 1.5 volts makes. The pump pumps about 20% faster with the motor running.
FollowupID: 12266
