GU 3L T.Diesel Towing Info Required
Submitted: Thursday, Aug 02, 2007 at 13:03
ThreadID: 48324 Views:3930 Replies:4 FollowUps:9
Hi, I am planning on selling up and travelling australia with my partner and 11 year old son. I have a 02 Nissan GU 3L turbo diesel and plan on towing a Jayco 24.75-1 (Ball Weight: 190kg - Tare Weight: 2175kg) . Can anyone tell me if this caravan is too big to tow with the 3.0L around australia, or where we can get further info?
Thankyou in advance
Amanda
Reply By: Brian B (Brisbane) - Thursday, Aug 02, 2007 at 14:01
Hi Amanda,
I would check the vehicle towing specs in the owners handbook and also check the rating of your tow hitch on the car. These should give you some helpful information.
AnswerID: 255477
Follow Up By: Amandaw01 - Thursday, Aug 02, 2007 at 14:09
Thanks Brian! Will do that. Was also wondering what the pros and cons are for towing such a big caravan.
FollowupID: 516629
Follow Up By: traveller2 - Thursday, Aug 02, 2007 at 14:59
If the Patrol is a manual it might be a pain as the motor doesn't have a lot of grunt till the turbo kicks in.
The auto allows the engine to get some revs onboard which means it pulls better off the line. From memory the auto has a 2.5t rating and the manual 3.5t, check the owners manuals and the towbar plate.
FollowupID: 516639
Follow Up By: Amandaw01 - Thursday, Aug 02, 2007 at 15:19
Appreciate you comments. Thankyou
FollowupID: 516644
Follow Up By: Macca_GU - Thursday, Aug 02, 2007 at 21:42
3.2t for the 3.0, 3.5t for the 4.2
FollowupID: 516695
Reply By: Member-Granpa Joe - Thursday, Aug 02, 2007 at 17:37
Your Patrol will tow this easily Amanda,
How many Km on the clock and have you had the clutch replaced yet?
AnswerID: 255509
Follow Up By: Amandaw01 - Friday, Aug 03, 2007 at 09:57
Just hitting 80,000 and no the clutch hasn't been done. Thanks
FollowupID: 516744
Follow Up By: Member-Granpa Joe - Friday, Aug 03, 2007 at 17:24
I would allow for an aftermarket clutch and flywheel assembly to be installed in your travel budget, I had to do this in my one at approx 80000 km and was the Only problem I have had with it to date. Although I should mention it has had a hard life.
FollowupID: 516813
Reply By: yakodi - Thursday, Aug 02, 2007 at 20:15
We have 02 Patrol 3L Manual, D-tronic helps a little. Towing 20ft 2,600kg Van with 2,500kg Vehicle. Well maintained vehicle but it hates the hills, 2nd gear not uncommon, but it gets there and we cruise on 85-95km/h all day on the highways. I should mention the only problem weve encountered was the engine failing after 120000kms.
AnswerID: 255535
Follow Up By: Amandaw01 - Friday, Aug 03, 2007 at 09:58
Thanks Yakodi. Are looking at the Dtronic.
FollowupID: 516745
Follow Up By: Amandaw01 - Friday, Aug 03, 2007 at 10:05
What was the issue with the engine at 120,000? Did you have to replace?
FollowupID: 516748
Reply By: Motherhen - Thursday, Aug 02, 2007 at 23:56
Hi Amanda
Check out thread 47718.
Is your Patrol auto or manual? Ours is auto, so your situation may be a bit different to ours if you have a manual.
We towed an 18' Bushtracker with a TARE of 2.2 t (i hate to think what the laden weight would be) with a 3 ltr td AUTO Patrol. Mostly no problems at all and it went well, but a couple of times from a standing start on a very steep hill, it really didn't want to hurry, which may have been due to the auto not coping. If we filled our water tanks (240 kgs), and had a full load of gear, we'd be way over the 2.5 t legal limit for the auto. The engine is the same in the manual and the auto - i believe it is the stopping power of the auto that gives it the lower rating. We did not risk anywhere with loose sand or deep water. Should we have lost our caravan breaks descending a steep winding road, we could have had difficulties if the auto could not cope with the load, but this is of course untested. All the same, it is not a comfortable position to be in knowing that in a difficult situation, you have no power to spare. Also consider how long the motor will last towing that weight all the time; as a 2002 model, you probably have over 100,000 kms on it already.
Also consider the gross mass of your vehicle. When you are fully laden (car and caravan) with yourselves, all you gear, food and clothes, you may well be over the gross mass permitted for the Patrol.
We also fitted EGT and Boost gauges so we could monitor and not overheat the motor as an added precaution.
All in all, it was a very comfortable and satisfactory vehicle for the short holidays, but we would not tackle the big lap with it towing a heavy van.
We have now purchased a 7.3 ltr td auto F250 so will have loads of power and breaking power, won't be out-weighed by the caravan, a huge tray to sleep on when we go off without the caravan, and confidence we have plenty of power to spare. There is not much out there bigger than the Landcruisers; F250s being the most common, Suburbans when you can find them, and a few imported from USA vehicles. They are expensive, but so are the latest Cruisers.
AnswerID: 255583
Follow Up By: Amandaw01 - Friday, Aug 03, 2007 at 10:02
Motherhen, thankyou for your detailed info. It is a manual and is just hitting 80,000.
FollowupID: 516747
