Remote Laptop Bootup
Submitted: Thursday, Aug 02, 2007 at 20:17
ThreadID: 48336 Views:2363 Replies:7 FollowUps:1
One for the computer experts.
I'm running Oziexplorer through a touch screen using a Compaq laptop.
I want to mount the laptop in a location which will mean it will be difficult to open the lid and turn the laptop 'on'.
Is there a way to boot up the laptop by simply applying voltage to the power supply plug and not have to open the lid and push the power button?
nrb1748
Reply By: KSV- Thursday, Aug 02, 2007 at 20:54
Nope, not as simple. If you do not like to do anything at all to computer, then only limited options remains - use wake-up facility on modem or LAN. It would require however some other device (sender). If I try to do something like that I would carefully open laptop and connect relay in parralel to "on" switch. Plus make some kind of delay device (really simple - numerious kits can be obtain from Jaycar or DickSmith) to operate this relay in such way that it close upon electricity applay and disconnect in say 2-3 sec. Good luck.
AnswerID: 255544
Reply By: festy - Thursday, Aug 02, 2007 at 21:14
I just soldered a pair of wires onto the power button's contacts, and connected them to a 1/8" phono socket on the back of the laptop, then wire a momentary push button switch to a phono plug via some long wires and mount the switch next to my seat.
That way I can just unplug the switch and the laptop is back to normal.
AnswerID: 255549
Follow Up By: F4Phantom - Thursday, Aug 02, 2007 at 21:17
i have no reason to do this but thats a frigging good idea.
FollowupID: 516691
Reply By: shade10 - Friday, Aug 03, 2007 at 07:10
there should be in start, control panel, power options , a little check box for you to leave laptop running, mines called "when lid closed do nothing". Most laptops have this type of setting for this particular reason. if you have any trouble let me know or if your ion the newcastle area, i can help!! email is nhol0605@bigpond.net.au.
AnswerID: 255602
Reply By: ExplorOz Team - Michelle - Friday, Aug 03, 2007 at 11:15
Yep - As Shade says - that's what we do.
Michelle Martin
Marketing & Customer Support
AnswerID: 255634
Reply By: Alan H (Narangba QLD) - Friday, Aug 03, 2007 at 13:20
The closing of the lid was not quite the question me thinks! But it is important as is screen savers being immobilised.
The remote switch is a great idea. I use a touch screen so that at the end of a run I use the touch screen to hibernate.
Then when power is next switched on, the maps and OZi etc are all back in place ready for another day of action.
AnswerID: 255666
Reply By: shade10 - Tuesday, Aug 07, 2007 at 16:23
when you close the lid it will keep all of your programs running and what you had on the screen last. So if you have a map and other stuff running like music it will run and whne you go to open lid its all there, but you will need to plug in the powersupply. This is easier then pulling apart lappy and voiding warranty and or stuffing it up big time?????
AnswerID: 256268
Reply By: shade10 - Tuesday, Aug 07, 2007 at 16:25
or oput in a small form factor pc that you use a touch screen there are manufactures that do car pc and you can set it up how you like
AnswerID: 256269
