Magnum Air Compressors
Submitted: Monday, May 12, 2003 at 23:43
David from A-trek Camper & Camping Hire
I have a Magnum twin cylinder, belt driven air compressor, the Magnum company went out of business back in the mid 90's, my question is, does anybody out there have an electromagnetic clutch that they wish to part with, the clutch i have is a mechanically operated dog clutch, which is a bit of a pain having to stop the motor and engage the clutch, then start the motor again, thanking you all in advance. Dave
Reply By: Member- Rox - Tuesday, May 13, 2003 at 00:36
Can you use one off a air con pully from a wrecker???Around Oz 06/2004
19826
Follow Up By: David from A-trek Camper & Camping Hire - Tuesday, May 13, 2003 at 10:33
Thanks for the reply Rox, however i have already tried this avenue, the problem is all the aircon pulleys i've looked at are to big ( 5" & up ) and have tapered shafts, the pulley i need, has to be at maximum 4" with a straight shaft , regards, Dave.
12632
Reply By: Member - Peter- Tuesday, May 13, 2003 at 18:39
Have a look at a late model toyota or similar small car they have smaller (around 4") clutches.
You can get a machinist to make a sleeve to fit the clutch to your shaft.
19904
