www.ExplorOz.com
Your browser does not support the site menu
Click Here
to load alternative navigation.
Latest News
Road Conditions
Updated 2/12/2008
Kimberley
Top End
QLD Coast
Outback NSW
Updated 1/12/2008
WA South Coast
Far North Qld
Road Conditions
All News...
Site Updates...
Search by Topic
4WD Treks
4WDriving
Accessories
Accommodation
Activities
Boating
Campers & Trailers
Camping
Caravanning
Communications
Cooking
Driving Skills
Electrics
Fishing
Itineraries & Planning
Membership
Motorhomes
Navigation
Permits
PlotSwap
Recovery Gear
Servicing
Survival
Technical
Things To Do
Topics
Tours
Trek Notes
Trips with Kids
Tyres
Vehicle Choices
Visit Australia
Newsletters
Not Registered
Register Now
Past Newsletters
Full Index
168
169
170
Current Users
Members
34
Customers
Visitors
11
Anon
447
Total
493
List...
Not Logged on
Any difference in oils for Diesels??
Submitted: Tuesday, Aug 28, 2007 at 15:32
Member -Signman
Article Overview - Oils and Lubes
Whether you drive an old or a new vehicle, oils and lubricants for your engine, diff and gearbox are critical factors affecting performance and also your running costs.
View Full Article...
If an oil is rated at (say) 20w-50 eg Shell Helix &/or Havoline Premium, is there any difference in the oils for use in diesel engines??
Do diesels need a 'special' brew - apart from the required viscosity??
Click Image to Enlarge
Each morning I seize the day...
but by mid afternoon it has escaped!
Signman- NSW
VKS737 R3364 Selcall3364
Amateur Callsign: VK2EZY
Member:
My Profile
Advertisement
Suppress Advertisement - Members Only
X
Forum FAQ
AnswerID: 259234 Submitted: Tuesday, Aug 28, 2007 at 16:01
MEMBER - Darian (SA)
replied: As I know it, the grade and the viscosity are the main factors it seems - then you choose the brand. Grades change for the various engine types - all to do with what the manufacturer recommends - fuel types mean a lot too I guess. Isuzu specify a CG-4 grade for my Jackaroo TD, with a range of viscosities that can suit varying temperature zones. I use Castrol Magnatec 10W-40 but there a quite a few others makes that would be suitable. There are a few expert sites on the topic - eg.
http://www.carbibles.com/engineoil_bible.html
When I'm too old to go bush, I'll have all my gear set up just right ! .... the "house" left ? - main corner, main street, Windorah QLD - priceless!
Member:
My Profile
Reply 1 of 6
FollowupID: 520733 Submitted: Tuesday, Aug 28, 2007 at 20:31
Cram posted:
I am new to Diesel motors but when I got my Disco TD5 earlier this year, the mechanic I rang in Newcastle, who has been dealing with Landrovers for years said, "make sure you use the right oil, if you don't you will have trouble." He uses and recommends Castrol Magnatec.
AnswerID: 259235 Submitted: Tuesday, Aug 28, 2007 at 16:07
replied: Just looking at that bibles site - seems like the CG-4 designation would best be termed the 'category' (there's about 13 of them listed) - grade is still commonly used in reference to viscosity.
Member:
My Profile
Reply 2 of 6
AnswerID: 259236 Submitted: Tuesday, Aug 28, 2007 at 16:13
Mainey (WA)
replied: Diesel's use 'different' oil to petrol engines, which can be seen in the oils
technical
specifications. The viscosity is not the main difference as often it's similar or the same.
That's why some oils are rated for "old" engines, some for "new" engines and some for "Diesel" engines which produce soot and require a cleaning agent added which is not in the oil for petrol engines.
Reply 3 of 6
AnswerID: 259242 Submitted: Tuesday, Aug 28, 2007 at 16:39
True Blue
replied: Signman, just recently I asked my mechanic son whether he would service our D40 t/diesel Navara. Yes, and he would look up what the required grade of oil was required as specified by Nissan.
The son suggested that we run a fully synthetic oil which covered the grades required by Nissan. No worries I said, go for it.
And I'm glad I did. He chose Mobil 'Delvac 1' and we purchased 15 litres (enough for 2 oil changes) for $150 which I reckon is pretty damn good.
Well we changed the oil and pretty much changed the engine.
From cold it felt as if it had been driven for half an hour. Very smooth, much quieter, and pulled as though it had been warmed up. The mileage on the tank increased from 700ks (before warning light comes on) to over 790ks and the light still hadn't come on.
I thought how grouse is this? The oil exceeds the manufacturer's recommendations, makes the car perform better and much more economically in the process.
Check it out, I can't recommend this oil high enough.
Cheers, True Blue.
Reply 4 of 6
FollowupID: 522226 Submitted: Friday, Sep 07, 2007 at 00:03
blown4by posted:
It might be worthwhile checking the Nissan handbook again because as general rule Nissan advise against fully synthetic oils in their diesel engines. For example on the ZD30 they advise against using any oil that exceeds CF-4 and there is a Nissan service bulletin that specifically warns against this. If they say in your handbook fully synthetic is OK well that is fine then, but if not it would be a shame to save a few cents on fuel consumption and then have to pay out big time for an engine rebuild. I am no lubrication engineer but in laymans terms it is to do with the higher compression pressures, piston ring materials and the fact the fully synthetic oils are in effect too effective at doing their job. This prevents the rings from bedding in properly and maintaining a good seal against the cylinders which then causes the cylinder bores to glaze up and the engine then starts to burn oil which is only reversible with an engine rebuild.
AnswerID: 259262 Submitted: Tuesday, Aug 28, 2007 at 18:54
Member - Phil G (SA)
replied: Signman,
Firstly, a
disclaimer
- I'm no expert, but this is the way I see it and welcome any corrections.
The difference is in additives. Put simply, diesel oils have more detergents to handle soot better. Petrol engine oils also contain detergents, but its not as critical.
Your 1Hz is an old fashioned indirect injection diesel, so it produces a bit more soot than the modern direct injection diesels. You'd be better off with a diesel engine oil, as soot can lead to oil thickening.
Many diesel engine oils are marketed as mixed fleet - so can be used for petrol as well as diesel vehicles.
If cost is a major consideration, a 15W40 Ci-4 mixed fleet oil like Fuchs Universal HD , or Gulf Western Top Dog will be fine in your 1Hz. I buy them for under $80 for 20litres from the truck shops.
LandCruiser HDJ79
Member:
My Profile
Reply 5 of 6
FollowupID: 520712 Submitted: Tuesday, Aug 28, 2007 at 19:09
Exploder posted:
Right, It's in the additive package in the oil.
Some oils can be used in both Petrol and diesel engines, Castrol, Penrite and Amsoil are the ones i can think of that have duel usage oil, i am sure other do as well.
I use a Amsoil Diesel oil in My Turbo Falcon as after talking with amsoil and doing some reading I decided it was the best Oil suited to my application.
Cheers.
FollowUp 1 of 2
FollowupID: 520716 Submitted: Tuesday, Aug 28, 2007 at 19:39
Member - Phil G (SA) posted:
Exploder,
All the oil companies have mixed fleet oils. Thats what the majority of workshops (including dealers) use. Its always interesting to extract from the suited guy behind the counter exactly what oil they put in your diesel motor, and they sheepishly tell you its a CF grade something, that you paid top dollar for.
But most of the newer petrol motors want a 5W30 or 10W30 these days, so you can't use the same oils.
phil
LandCruiser HDJ79
Member:
My Profile
FollowUp 2 of 2
AnswerID: 259323 Submitted: Wednesday, Aug 29, 2007 at 04:34
Member - Bucky (VIC)
replied:
There are a million reasons hy you shouold type Engine OIL into the the
forum
search
bar, and look what happens.
A million different Ideas, but what they are basically telling you is to read your owners manual, and only use the recomended oil, with the specifications.
That way you should never go too far wrong.
Cheers Mate
Bucky
I must obey,, I must obey,, I must obey !
Member:
My Profile
Reply 6 of 6
Page Sponsors
WAECO Pacific Pty Ltd
WAECO, part of the International Dometic Group, is renowned around the globe as a progressive company with innovative products of high quality and reliability. In Australia, WAECO has made a name for itself in the Outdoor Lifestyle Industry, supplying mobile refrigeration and technology for people on the move.
1 JOHN DUNCAN COURT VARSITY LAKES, QLD, 4227
Phone: 1800 21 21 21
More info
Website
Driving Directions
Evakool
Australia's largest manufacturer of 12v/24v portable refrigerators and iceboxes. Made in Australia for Australian conditions. Using Evakool's renowned fibreglass insulated ice box as the basis for the fridge coupled with the worlds best compressor (Danfoss), these units offer the serious off-road traveller WORLDS BEST technology and performance at a great price.
16 ENTERPRISE STREET CALOUNDRA, QLD, 4551
Phone: (07) 5492 7777
More info
Website
Driving Directions
New/Updated
Mid West WA Explorer Card $20.00
Membership Personal - Lifetime $300.00
South West Map Book $9.95
Frogs and Tadpoles of Australia $19.95
Spiders Snails and Other Minibeasts of Australia $19.95
Dinosaurs and Other Ancient Giants of Australia $19.95
Birds of Australia $19.95
Australian Outback Yarns - Bull From The Bush $19.95
Fast Find
Shop Home Page
Discounted Items
Latest/Updated
All Items
Home
About Us
FAQ
Feedback
Site Stats
Membership
Advertising Campaigns
Site Updates
Forum
Blogs
Forum Archive
Trader
Shop
Treks
Places
Directory
Articles
Topics
RSS Feeds
Link to Us
Terms of Use
Corporate Membership
Privacy Policy
Copyright © 1999 - 2008,
I.T. Beyond Pty Ltd.
All rights reserved.
