AnswerID: 259930 Submitted: Sunday, Sep 02, 2007 at 07:55
Member - Burto (NSW)
replied:
Hi, Mark
It is a relatively straigthforward job. What you need is 2 stands to support the vehicle and another 2 to support the axle assebly, you could use a trolley jack but with the offset diff the assembly may tend to tilt.
It is then a case of removing the U bolts and the shackles, it is good idea to clean up all threads with a wire brush and a good spray with WD40 or similar.
When refitting the springs and shackles, fit the fixed shackle first and then the swinging shackle as this will give you a bit of movement to line up for the pin. If using rubber bushes use some liquid detergen or similar for lubrication, if using nolathane bushes use the supplied grease.
I fitted greaseable shackles to my 60 series with nolathane bushes it is now a simple task to grease and the nolathane bushes can do what they were designed to do and that is rotate with
suspension movement not twist.
Do not tighten the shackle bolts to their final torque until the vehicle is on the ground, bounce the vehicle a few times so that the shackle bushes can rotate into their normal working position and then do your final tighten. This applies to any
suspension work.
With the Ubolts tighten them to their final torque in diagonal pattern, remember that the U bolts you have tightened will loosen as the spring settles so check yheir torque a couple o times
Hope this is of assistance, good luck
Reply 3 of 4
