Site Search
Section Image
inverters and tv's with dvd
Submitted: Monday, Sep 03, 2007 at 20:39
kampenman
evening everyone,
would someone be able to infrm me on what size inverter i would need to run a 39cm widescreen LCD tv and a dvd player in the caravan. only now and then not all the time.
Pete
ThreadID: 49290 Replies: 8
Views: 759 FollowUps: 1
AnswerID: 260161   Submitted: Monday, Sep 03, 2007 at 20:49
replied:
G'Day Pete,
Suggest something rated above 900 watts peak, Guessing the T.V. would use about 500 watts and the DVD play 200 watts.
Have found from experience if you load the inverter to maximum it often splutters low battery and turns the T.V. off.
You can run some LCD's and DVD players straight off 12 volt, just need to check
Rolande
Reply 1 of 8
AnswerID: 260185   Submitted: Monday, Sep 03, 2007 at 22:08
Nick R (VIC) replied:
I have a 300w inverter and it runs my 17 or 19 inch telly well, not sure about a dvd
On a Dune that i was told was Big Red
Click Image to Enlarge
Aio, quantitas magna frumentorum est
Carpe Cerevisi
Reply 2 of 8
AnswerID: 260218   Submitted: Monday, Sep 03, 2007 at 23:53
LGen1 replied:
I run my 12volt 17 in LCD TV & DVD off the battery
Reply 3 of 8
AnswerID: 260239   Submitted: Tuesday, Sep 04, 2007 at 07:45
nickoff replied:
I would have a look at the plate on the back of the LCD TV and DVD player and check out the WATTS rating. LCD TV 39Cm should be less that 100w and DVD player abouy 25w or so.
Add a couple of low power fluros etc, about 300w inverter should cover it
Nick
Reply 4 of 8
Activities Index
Puffing Billy and Dandenong Ranges Half Day K5 Puffing Billy and Dandenong Ranges Half Day K
Melbourne - VIC
Journey with AAT Kings to the beautiful Dandenong Ranges and travel aboard Australia's oldest operat
Seal Watching Cruise Seal Watching Cruise
Phillip Island and Gippsland - VIC
Experience a true eco-cruise along the scenic coast of Phillip Island to Seal Rocks.
Introductory Diving - Byron Bay Introductory Diving - Byron Bay
Far Nth Coast / Byron - NSW
Learn to dive on this five hour introductory course, and experience the underwater brilliance of Jul
Stunt Driving Xperience - Spins and Slides Stunt Driving Xperience - Spins and Slides
Brisbane - QLD
Have you ever seen a great car chase in a movie where the car slides a corner, does a 180 spin, slid
Book Now - Things To Do
AnswerID: 260563   Submitted: Wednesday, Sep 05, 2007 at 20:05
kampenman replied:
thank you everyone,
a great help . is some thing like what was floating around my head.
Pete
Reply 5 of 8
FollowupID: 525612   Submitted: Tuesday, Sep 25, 2007 at 21:58
Mainey (WA) posted:
Pete,
Check the TV & DVD power requirements, just as Nick as posted, and you will have some factual figures to work with.
Check the "refresh rate" on a 12v TV and compare it to a 240v TV, then you will understand why the 240v TV has a clearer & clearer image.
AnswerID: 263721   Submitted: Monday, Sep 24, 2007 at 13:02
David from EAC Supplies replied:
Yes we would say check your rating of your two devices and add maybe 20% for safety so it does not cut out!
EAC Supplies
Member: Lapsed Membership
Reply 6 of 8
AnswerID: 263891   Submitted: Tuesday, Sep 25, 2007 at 18:26
disco1942 replied:
When you operate equipment off a battery you should do everything you can to reduce losses. Most small consumer devices operate from 12V or similar voltages. Some of these have an external power brick and some of them have internal power supplies that convert the 240V mains power to the lower working level. These power supplies introduce power losses into the system. If you run 240V appliances through an inverter you introduce further losses, the larger the inverter you use the higher these losses are.
If you are running a TV set through an inverter you can be loosing 1/3 of the power you are drawing due to the losses in the inverter and the power supply. To put this in its true perspective - when running the TV through the inverter you are using 50% more battery power than if you run it directly from the battery.
Most of the "12V equipment" you see in shops is just 240V equipment that is also supplied with 12V power lead and has an inflated price. A cheaper way to acquire 12V equipment is to select equipment that is powered from the mains via a 12V power brick. Construct (or have someone else construct) or purchase a separate 12V power lead. This can be a much cheaper way to go.
Reply 7 of 8
AnswerID: 263963   Submitted: Wednesday, Sep 26, 2007 at 00:13
Mainey (WA) replied:
All Inverters loose some current as a percentage of their total output, however the better quality Inverters loose under 10%, like anything you can buy cheap elcrappo products - but you get relevant results.
This loss does NOT effect the running of the 240v product it is running.
The 'loss' is only counted as a loss in the battery consumption numbers, so it's only minuscule when compared to the consumption of the product, eg TV
That's why a "quality" Aux battery system is used to counter ALL the power consumption (loss's) from ALL accessories, including the fridge, lights & inverter etc.
Example:
OUTPUT POWER: 200W continuous - 600W surge
OUTPUT VOLTAGE: 240VAC +/- 2% ( PURE SINE WAVE )
EFFICIENCY : 96 %
Price: $264 delivered
These Inverters provides clean, silent 240V AC power for your mains appliances from 12 volt battery power and provides a PURE sine-wave output, which is the cleanest power available for those applications that require the very cleanest & purest in power. They are microprocessor controlled and have full electronic fault protection. They also have LED indicators to indicate Power and Fault conditions. The unit also features a very low standby current to save power.
Reply 8 of 8
 Page Sponsors
Phone: 1800 21 21 21
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
