49197 dog traps
Submitted: Tuesday, Sep 04, 2007 at 18:04
ThreadID: 49324 Views:1711 Replies:2 FollowUps:6
Thank you for all the help and suggestions. I've got enough info now to build one and all that is left to do is to weld it up. It's a combination of a lot of ideas and designs. Will advise its success or otherwise once I've tried it but will be overseas until early October so trial will be delayed.
The suggestions about getting in touch with the SSAA will be followed up as they have a shooting range about 25km down the road from the block.
Once again thank you for the assistance.
Geoff
Reply By: Member - Kim M (VIC) - Tuesday, Sep 04, 2007 at 21:33
Geoff
I put a fair bit of time into this (along with others that I've spoken to) attempting to help you. Next time you ask for advice, be mindful that people do put a bit of effort into responding to a member post.
The issue your dealing with is complex and needs a fair bit of input from your side. If your not prepared to do that, the post was a waste of time.
I was going to meet up with a couple of fella's from a local Rifle Club to discuss your problem, but have cancelled that now.
Kim
AnswerID: 260380
Follow Up By: Geoff (Newcastle, NSW) - Tuesday, Sep 04, 2007 at 22:46
Kim,
I'm quite curious here, how'd you arrive at the conclusion Geoff hasn't put "a fair bit of input from your side" and should effectively be written off?
Geoff
Geoff,
FollowupID: 521793
Follow Up By: stocky - Tuesday, Sep 04, 2007 at 23:44
got me puzzled too..........
FollowupID: 521801
Follow Up By: Member - Geoff C (QLD) - Wednesday, Sep 05, 2007 at 10:10
Sorry if I caused any inconvenience. I've decided to try the trap first and if that doesn't work then all other methods will be tried. Our councils up here are tied up with the amalgamation fight and are obsessed with that. I only go up to the block occasionally and had the time to build the trap now (retirement is great).
Geoff
FollowupID: 521861
Follow Up By: Member - Kim M (VIC) - Wednesday, Sep 05, 2007 at 18:00
Geoff (QLD)
Sorry about outburst.
I had a buggar of a day at work yesterday. After I read your post, I then had to ring the guys and tell them to turn around and go home. They weren't all that happy.
Good luck with your trapping.
Kim
FollowupID: 521944
Reply By: Member No 1- Wednesday, Sep 05, 2007 at 07:43
you should use the Hunting & Conservation Branch as listed on the SSAA web site.....not just you local SSAA gun club...
AnswerID: 260418
Follow Up By: Member - Davoe (Nullagine) - Wednesday, Sep 05, 2007 at 18:24
Cmon you know you want to
FollowupID: 521955
Follow Up By: Member No 1- Wednesday, Sep 05, 2007 at 20:50
yep i do...but qld is too far away for a dog or two...have better fun...er should i say... more demanding challenges here in SA closer to adelaide
FollowupID: 521985
