Noisy roof rack
Submitted: Wednesday, Sep 05, 2007 at 21:31
Angler
Has anyone found a method of lowering the wind noise of a roof rack?
Mine is one of those oval tube aluminum models with the perspex sloping front panel.
I have it mounted so the slope is just past the slope of the screen.
A speeds around the 100kph mark the wind noise is pretty bad.
I know the best way is to remove it however I just purchased it for a specific trip.
Pooley
Reply By: Michael ( Moss Vale NSW) - Wednesday, Sep 05, 2007 at 21:38
I have a full length alloy rac and moving it back as far as practical helps. Michael
260583
Reply By: howie - Thursday, Sep 06, 2007 at 00:20
i had
mine almost level with the rear doors, no problem.
then i had to move it forward to your position for a reason and the noise is very noticable.
try moving it backwards.
260615
Reply By: Skippy In The GU - Thursday, Sep 06, 2007 at 07:21
I've on a couple occasions turned up the radios a few notches :-)
260629
Reply By: tdf - Thursday, Sep 06, 2007 at 08:29
the original plastic wind deflector often just fits on the top and bottom bar leaving a large gap between the roof and the rack,i nade a clear perspex deflector that goes to within half an inch of the roof and one inch higher than the rack....result...absolutely no noise at all.
260641
Follow Up By: Angler - Thursday, Sep 06, 2007 at 21:41
Sounds like a good idea, More expensive than other suggestions but
well worth a try.
Pooley
522204
Reply By: Member No 1- Thursday, Sep 06, 2007 at 10:17
your obvoiusly going too fast.....slow down...wont make so much noise and the others will be able to keep up with you
260656
Follow Up By: Angler - Thursday, Sep 06, 2007 at 21:39
If I slow down the followers get cranky. I reckon 100 is fast enough.
Pooley
522203
Reply By: Wizard1 - Thursday, Sep 06, 2007 at 11:01
Ahhh, the perspex front wind deflector, useless in cross winds and when you load up the roof rack. Best advice I got from ARB when I got
mine fitted was not to bother with the deflector as they do nothing.
There is absolutely no way you can make a roof rack more aerodynamic and produce less noise.
The only way to stop the wind noise is to take the roof rack off or learn to live with it.
Took
mine off for a while as the car wouldn't fit in the garage. Put in on for a trip and left it on as I use it too much for other stuff. I travel the M1 between
Brisbane and the
Gold Coast with mainly easterly cross winds and you just learn to live with it and turn the radio up.
260668
Reply By: Andrew from Vivid Adventures - Thursday, Sep 06, 2007 at 12:14
yeah.
Took it off and migrated to a trailer.
Much the same economy and more comfortable travelling.
260682
Follow Up By: Angler - Thursday, Sep 06, 2007 at 21:38
Andrew, We already tow an 18ft van so a trailer is a bit difficult however I do agree with you.
522202
Reply By: Member - John L G - Thursday, Sep 06, 2007 at 16:32
Sounds silly but chuck something up there, nearly anything will do but seems to work.
Certainly does on my son's 100 series with ARB rack fitted.
260728
