What battery?
Submitted: Thursday, Sep 06, 2007 at 10:20
KSV.
G’day everyone!
Is anyone can tell me what is consensus what brand of batteries the best? “Best” here means most reliable and cost reasonable money. Question arouse because recently I have 2 faulty batteries in passenger cars. Both were top range of Exide maintenance free batteries with fancy window indicator to judge battery condition. Both of them were less then 24 month old. If one try to go and pick a battery from retailer it is became very frustrating exercise indeed. It appears as everyone stock only one brand and obviously swear on them. Where I can find fair comparison? I do not mind to check liquid level in battery, but I do mind if dumn thing went into complete death without any warning and after mere 20 month in service.
Thanks.
Reply By: Sand Man (SA) - Thursday, Sep 06, 2007 at 10:45
We need more infomation matey.
There is certainly nothing wrong with the Exide brand of battery, but under what conditions is the battery being used?
Is it simply a starting battery or an auxiliary battery for running a fridge.
If the use is purely for starting then I would be looking for an underlying cause of premature battery failure as you should expect a longer life than two years.
If you were trying to use a starting battery to run a fridge, or other higher current draining device, then the wrong battery is being used. In this case a deep cycle battery is required.
The best solution is to pop along to a battery retail outlet where a proper analysis of cable connections, the alternator charging rate and battery load testing should identify the cause.
260663
Follow Up By:- Thursday, Sep 06, 2007 at 10:57
Purely for starting a passenger car in both cases. Given that battery exactly the same been failed in two different cars within very close period means that it is incredibly unlikely that alternators circuit been damaged in both vehicles.
522107
Reply By: Member - 'Lucy' - Thursday, Sep 06, 2007 at 10:52
Don't know where you are from dude, however I strognly recommend that you consult your 'White Pages' and identify retailers in your area that stock a wide range of batteries.
Then seek their advice for whatever application it is that you are trying to get this
forum to advise on.
Best of British luck to you in your endeavors.
260665
Follow Up By:- Thursday, Sep 06, 2007 at 11:07
Thank you very much dude for informative answer. I finished with buying battery from "battery only" place and guess what? - they stock only one brand and swear on it. Advice from them is very simple (as from anyone else BTW) - buy from us, we are specialist. Problem with battery is similar to problem with tyres - you never know what is good and what is bad until it is too late. Consulting to so called specialists does not mean much because they want to sell their stuff and therefore will tell you everything what you want to hear to make you withdraw your wallet. This is why I will value opinion of real people much more then so-called specialists.
522108
Reply By: Sand Man (SA) - Thursday, Sep 06, 2007 at 11:43
Well then,
The starting battery I use is an Exide Extreme which is purpose designed for the sort of treatment encountered in 4WD travel, i.e. corrugated tracks, etc.
260677
Follow Up By:- Thursday, Sep 06, 2007 at 12:44
This is exactly what I have in my LC. Now with two other Exide batteries failed make me thinking if they really so tuff. While failing battery in family
sedan means only time inconvenience and hundred-ish lost, same thing in 4WD in remote area can lead to much serious consequence. In contrast I use to have "normal" Exide battery (not extreme) in my old 60 LC for 5 years and when sold it still was cranking.
522120
Follow Up By: Member - andrew B (Kununurra) - Thursday, Sep 06, 2007 at 17:38
I'm an exide extreme fan as
well, and with the heat up here you don't expect much more than a coupe of years out of them, and with a 2 year warrenty its all good. I have only ever claimed one, the last starter failede after nearly 3 years, I probably would have got a bit more out of it, But an aging battery doesn't like headlights being left on for 2 weeks.....
At a local Ag show, a rep was trying to sell the pricey glass mat jobbies. Was saying they will last 5 years, so I told him to give them a 5 year warrenty and I'll buy 2 on
the spot. Funnily enough he said no.
Cheerw Andrew
522158
Reply By: Moose - Thursday, Sep 06, 2007 at 13:26
Mate - you will never get a consensus opinion on this site on which is the best battery. There are heaps of types and brands of batteries out there and they're probably all used by people on this
forum. Personally I stay away from the big name brands because I'm not convinced they are any better than the cheaper ones - been caught in the past. 20 months is very short - perhaps you need an auto electrician to check out the charging system.
260694
Reply By: Member - Phil G (SA) - Thursday, Sep 06, 2007 at 14:07
Like you I never had much luck with the wet cell "Maintenance free " batteries.
Go back to the "low maintenance" Exide or Century batteries. We run 5 other vehicles in our family and usually get 6 years out of a car battery.
260702
Follow Up By:- Friday, Sep 07, 2007 at 09:02
===>Go back to the "low maintenance" Exide or Century batteries.
This is what I have concluded. No more funcy stuff anymore - only plain "standard" battery from now on.
Cheers.
522245
Reply By: DIO - Thursday, Sep 06, 2007 at 14:42
To get the best performance out of any battery, the experts will tell you to consider the importance of correct charging rate, cycle, operating temperatures, wiring etc etc. Best advice I can give is to buy yourself a Mega Pulse battery conditioner. Cost about $100 and will extend the life of your battery by many years by preventing sulphation of the cells. I have used them for many years and they are the best investment I've ever made re battery care etc. No I am not affiliated with the product, only a very satisfied customer. I have vehicle batteries that are still performing as new after 5 - 7 years.
260710
Reply By: Dave Thomson - Thursday, Sep 06, 2007 at 14:45
As I used to work for century batteries I can tell you THEY ARE ALL THE SAME, the warrenty is just the same in all of them, for your info to buy in a typical battery for a falcon thats the case, cells, acid ,transportation, storage etc, costs about $18.00, and they sell for about $100.00 and thier mostly all owned by one company, for example if a customer walks and asks for a battery for a BMW, and there is'nt one you can "legally" take the sticker off a Besco and sell it as the one the customer wants, I personally thought this was fraud as he paying a lot more money for something that isn't what he wanted but century have the rights to a whole range of other brand name batterries and this was standard practice when I was there some years ago, but no matter how you parcel it up there are none better than others, if you get a good one you can just as easily get a bad one of the same brand,
hope this helps,
260711
Follow Up By:- Friday, Sep 07, 2007 at 08:59
Thanks,interesting reading.
522243
Reply By: Andrew from Vivid Adventures - Friday, Sep 07, 2007 at 10:49
troll troll troll
260848
Reply By: Mainey (WA) - Friday, Sep 07, 2007 at 19:07
Buy a known and reputable brand with a long warranty :-))
260919
