water on demand
Submitted: Thursday, Sep 06, 2007 at 22:44
ThreadID: 49416 Views:2197 Replies:10 FollowUps:5
have a coleman hot water heater, it seems to light then goes out almost straight away. have read before some others have had this problem, anyone know how to fix it? its out of warranty.
Reply By: Member - 'Lucy' - Thursday, Sep 06, 2007 at 23:23
Interesting point that you raise.
I bought one of these thing-a-me jigs about two 4WD shows ago just to shut SWMBO up.
Never used it and never test fired it.
Maybe it will be a surprise package.
AnswerID: 260801
Follow Up By: Blaze - Friday, Sep 07, 2007 at 03:08
We had one and it was amongst a bad batch, so they informed me. Snowy's in Adelaide changed it over and the new one has never missed a beat.
FollowupID: 522227
Reply By: Skippy In The GU - Thursday, Sep 06, 2007 at 23:26
I have said in a previous post there was a bad batch, you could still take it back and claim warrenty, I did after 2 or 3 years.
AnswerID: 260802
Reply By: Dunedigger - Friday, Sep 07, 2007 at 07:05
If the one you have is the same as mine, Blue metal box, I found it worked reliably if I removed the front cover ( 3 screws ) and left if off. At low water temps it kept going out
Dunedigger
AnswerID: 260809
Follow Up By: Member - Andrew (QLD) - Friday, Sep 07, 2007 at 07:28
I never knew the Coleman Hot Water on Demand units came in a blue metal box......they have always been green plastic AFAIK. :-)
FollowupID: 522229
Follow Up By: Dunedigger - Friday, Sep 07, 2007 at 07:29
OPPS,,,,, Sorry mine is a Primus Sorry Sorry sorry . .
FollowupID: 522230
Follow Up By: Member - Andrew (QLD) - Friday, Sep 07, 2007 at 07:35
LOL.....you get that sometimes.
FollowupID: 522231
Reply By: Member - Andrew (QLD) - Friday, Sep 07, 2007 at 07:32
Apart from the initial batch problems (i wouldn't have thought that it be that problem after so long), i have found that mine goes out if the battery is getting low.......it will pump, though not light.
Charge the battery.....maybe needs a replacement one.......and see how that goes.
AnswerID: 260812
Reply By: The Bigfella - Friday, Sep 07, 2007 at 07:52
I bought a Coleman about 3 years ago and it played up from day one the same as yours is. I had it repaired by Coleman (in Sydney) but it only lasted a few uses and stopped working altogether.
I contacted Coleman and they told me to take it to the nearest Coleman stockist (I live in Bathurst) and it was replaced with no questions asked.
As said above there was a bad batch sold in Australia and I notice the new ones now come with a five year warranty.
By the way when working properly they are a great machine.
The Bigfella
AnswerID: 260813
Reply By: David - Friday, Sep 07, 2007 at 11:02
Hi Shane,
I had the same problem with mine, it turned out to be a small amount of crap in the filter at the end of hose. There is a small piece of mesh that was slightly blocked, it still pumped water and light, then go out. I cleaned it out, then no Problems since.
Hope this helps,
David
AnswerID: 260850
Follow Up By: Ross H (QLD) - Friday, Sep 07, 2007 at 12:26
Yep agree with david .ours done the same and was the pump filter
FollowupID: 522268
Reply By: Member - shane (SA) - Friday, Sep 07, 2007 at 21:03
thanks for replies, contacted coleman and they are going to replace it.
AnswerID: 260940
Reply By: Axel [ the real one ] - Friday, Sep 07, 2007 at 21:05
Remove the screw holding the black control knob , gently pull the knob out and remove the spring , replace knob and screw , effectively disables the auto flame cut out , have had ours like that for the last 3+ years no problem.
AnswerID: 260942
Reply By: Member - Debbie R (SA) - Saturday, Sep 08, 2007 at 17:29
Our unit is fantastic we now use it from a 9kg bottle and the only time we have ever had a problem like you are describing is when the battery was low, keep it charged and you will have years of great use.
DEBBIE
AnswerID: 261046
Reply By: Brew34.5(SA) - Saturday, Sep 08, 2007 at 19:24
Glad to see them coming to the party......you had me confused when you said it was out of warranty, as they have a 10 year warranty and they haven't been around ten years.
AnswerID: 261074
