Rear storage draws
Submitted: Sunday, Sep 09, 2007 at 12:52
Hairy
Gday,
I'm looking at buying a set of storage draws for the back of my 80 Series for our trip over West.
There seems to be a lot of different brands and prices around these days so I thought I save time and ask.
Has anyone recently bought a draw system or looked in to them?
Is there any brands I should avoid?
As I said they are to go in a 80 Series, and need to fit a 60l Waeco fridge on slide on top of one side. They need to be heavy duty (steel covered in carpet) not timber.
Can any one recommend a brand to start looking at?
Hairy
Reply By: Member - Kim M (VIC) - Sunday, Sep 09, 2007 at 13:11
Hairy
I have an OutBack Systems unit. Black Widow are just as good. Neither are cheap, but it's the best piece of gear I've ever purchased.
Apart from general storage, their good to lock valuables in when the car is unattended.
Kim
261197
Follow Up By: Member - Phil G (SA) - Sunday, Sep 09, 2007 at 21:12
Had a friend who liked the idea of locks on his Black Widow drawers. But when you pull the fridge slide forward, you could access the contents of the drawer...............
522614
Reply By: barney rubble - Sunday, Sep 09, 2007 at 13:27
Gday hairy as kim said outback drawers are expensive but ive had them in 2 patrols and searched high and low for something as good before the 2nd set and like everything found ya get what ya pay for went one better on the current set and got the storage rack and divider most expensive bit of mesh ive ever bought but saves everything from falling over the fridge and as yet to req a roof rack for the
camping gear Cheers
261201
Reply By: Sand Man (SA) - Sunday, Sep 09, 2007 at 13:33
Hairy,
IMHO you can start with the Black Widow system which in my opinion is the very best, and then use this as the benchmark to compare any other brand and their features.
I looked at a few different brands, one of which is distributed by a
well known 4WD outlet and,
well it just didn't "scrub up" for the small price difference.
The Black Widow system has everything you are asking for and the best thing is that when you change vehicles, you merely buy a new set of side "wings" to suit the new vehicle and swap everything else over.
I'm more than happy with the system I selected and the price I paid has been a worthwhile investment.
Although the manufacturing plant and head office is in
Melbourne, I think there is an arrangement with distributors in most states to do the installations work.
261203
Follow Up By: Member - Mark E (VIC) - Sunday, Sep 09, 2007 at 14:48
I second the comments here.
I've made my own in the past from Timber etc, but decided to lash out this time and buy the BW ones. They were fitted poorly by the installer and rattled. Upon return from the 12,00km trip that I was on at the time, I rang BW direct and they were most obliging. They fully removed the drawers, replaced a dud bearing, re-installed them PROPERLY...apologised profusely and promised that they would followup with the installer with some retraining.
Gave me some complimentary items too.
Very good service from BW....great product. Would reccommend.
Mark
522560
Reply By: Hairy - Sunday, Sep 09, 2007 at 13:55
Thanks Kim, Barney and Sand Man,
Ive emailed them for a quote.
Ever heard anything good or bad about the Tanami Draws?
Hairy
261207
Follow Up By: slave - Sunday, Sep 09, 2007 at 14:09
No personal experience but met a couple that were on a trip around Australia who had purchased a set of Tanami drawers and they were very impressed with their purchase.
Mrs S
522558
Follow Up By: Member - Kim M (VIC) - Sunday, Sep 09, 2007 at 14:50
Hairy
Further to my earlier reply. This is what I'd be looking for:
1. Quality of roller system.
2. Thickness of the sheet metal. I came across a guy who had a unit that was paper thin. He said the rattling drove him up the wall.
3. Good quality locks.
4. If your running a 60L fridge you'll probably need at "set down" as shown on their web site.
5. Have a real good think about what you need or want. For example (in my case):
The back
seat was taken out and a bed extension added.
Underneath the extension is a 60L
water tank and compressor. The remaining room holds a 2KVA Honda generator and rifle.
If there are two people sleeping in the car, the fridge is pushed out and a section placed in
the gap. This requires the back door to be open, but all I do is put up a simple tarp which only takes a couple of minutes.
Kim
522561
Reply By: Jimbo Vic - Sunday, Sep 09, 2007 at 14:16
Hairy,
Properly constructed timber drawers will offer all the strength that is needed.
Wood has been used for thousands of years in boats, and still is with great success due to its strength to weight ratio.
My drawers are made from structural ply, cut on a $110,000 CNC Flatbed Routing Machine, have 3mm Gal Steel rails and 40 roller bearings.
My guarantee is simple. If you're not happy with it, send it back, I'll pay the freight and refund your money. Not one has come back yet.
And I do a matching fridge slide.
Jim.
261210
Follow Up By: harpo - Monday, Sep 10, 2007 at 22:50
Harry
I agree with most very thing jim has said. Timber is structurally sound if designed correctly. Check out
[url=
http://www.autodraw.com.au]
Always look for bolted not screwed
Harpo
522818
Reply By: A J - Sunday, Sep 09, 2007 at 14:27
Hairy,
We have a set of Offroad Systems - work very
well - they will build what you want - went to others as my wife is short and would not be able to see in the engel fridge if slide was on top of a draw - was told to carry a stool for her to stand on.
AJ
261211
Follow Up By: Member - Earvin (NSW) - Sunday, Sep 09, 2007 at 21:41
I Offroad Systems as
well. Have found them to be of high quality.
522619
Follow Up By: pt_nomad - Monday, Sep 10, 2007 at 06:43
Hairy,
I alos have an offroad systems (
sydney) draw set up as
well. I ended up there because Graeme is the only bloke I found who has a system that is flexible enuight for you to design the size and shape that you are after. To date I am very happy with the unit.
As mentioned above fridge height is an issuse, especially with a 60l waeco - they are very tall fridges. You don't want to have to climb up onto the back of the vehicle every time you want to get something out of the fridge. IMO the fridge should be mounted at floor level.
Paul.
522645
Reply By: Member - lyndon K (SA) - Sunday, Sep 09, 2007 at 15:46
Outback drawers are great, had the same set in three Troopys now and they are still going strong. They can custom make the depth of the drawers for you too,
mine are 300mm deep.
Cheers Lyndon
261221
Reply By: Cram - Sunday, Sep 09, 2007 at 16:55
Thanks to a second job I lashed out on a set of Black Widow Drawers and I am very happy with them. What sold me on the BW is that they are easily transferred to other vehicles.
261230
Reply By: Hairy - Sunday, Sep 09, 2007 at 17:05
Thanks everyone
261231
Reply By: Willem - Sunday, Sep 09, 2007 at 23:50
Last hurray, Hairy
I've just remodelled the GQ storage facility. I use MDF and angle brackets and the ideas flow freely when building. If it doesn't work this trip then I will make it to work next time.....lol.
All up cost $100. Yerr.......its Willem-bilt
261301
Reply By: Steve - Monday, Sep 10, 2007 at 00:03
Got a set of second hand Outback Drawers that i took out of 80 series when i sold it ....but by all accounts of so called 'visitors'....the Black Widow are better !!!
WELL NOT IN MY HONEST OPINION ....
261302
Follow Up By: Member - Crazy Dog (QLD) - Monday, Sep 10, 2007 at 12:45
Steve are you saying that you have a set that you took out or your 80 series to sell?
Grrr!!!
522687
Reply By: marcus - Monday, Sep 10, 2007 at 07:43
Hairy,
Mine are from Fourby Fitouts and are a great set up.Strong ,really
well made and a great fit.At first i baulked at the cost but after watching them being installed i reaised how much work actually goes into them.System in
mine has been in now for over two years and not even a rattle any where.
www.fourbyfitouts.com.au
cheers Mark
261308
Reply By: trouper - Monday, Sep 10, 2007 at 18:39
Hairy
Sorry for the late reply but I agree with others, that Offroad Systems of Narellan, NSW are great and at the right price. Have had then in my troopie for four years. Grahame will do it your way with extra hints to make live comfortable in the bush.
261407
Reply By: Richard W (NSW) - Tuesday, Sep 11, 2007 at 07:47
Hairy,
Another late reply on the Off Road System drawers.
I just did 15,000KM WA trip including the Tanami and Plenty/Donahue with no dramas.
261488
Reply By: Truckster (Vic) - Tuesday, Sep 11, 2007 at 07:54
why not make your own? theres plenty of plans on this site for them, and save yourself over a grand n half in most cases.
261492
